The manual for an Englander stove says, "never burn...kiln dried
wood". Is this because kiln dried wood isn't really dry enough, or because something is permanently wrong with it?
Filling a stove with a full load of construction cutoffs is going to take off with a very hot fire.
Can't you prevent the "take off" by shutting down the air supply?
Which stove and what page of the manual are you talking about?
In a modern EPA-stove you cannot snuff out the fire by reducing the primary air.
Who said anything about extinguishing? I'm just wondering how to prevent an overfire with kiln dried wood.
In a small firebox stove it's going to be hard to load it up with large pieces of wood. A load of super dry small pieces of wood will ignite and burn quickly. The way to control the fire is to not do this in the first place.
Kiln dried lumber is 15% to 20% moisture, at least when new, and then reaches the same equilibrium moisture content as any other wood.
I have a somewhat related question- what about a dead standing tree or very dry large limbs that fall. If you cut a tree like that and split it and try to burn exclusively it would it "over burn" your stove? Is there a mean MC count that you should follow like "don't burn wood greater than 20% moisture but not less than 10% " or something like that? I'm not talking burning with lumber scraps ....
I just checked some splits from a standing dead hickory, that i css in march, it is around 18%. The standing dead pine that i css a week ago is 45%.I have a somewhat related question- what about a dead standing tree or very dry large limbs that fall. If you cut a tree like that and split it and try to burn exclusively it would it "over burn" your stove? Is there a mean MC count that you should follow like "don't burn wood greater than 20% moisture but not less than 10% " or something like that? I'm not talking burning with lumber scraps ....
The oak pallets I have been burning that I get from work usually measure 5% moisture or less. They burn very quickly. I could see how it could easily overfire a stove. I just use it as kindling or to mix with 20-25% wood
My bad! Thought it was much drier.![]()
Since you can't shut off all the intake air the only option that would slow the fire would be to open the door...
