king PK130 which thru wall exh pipe kit to buy?
gerard jones
7
maine
Hi , I bought a king pk130 with no pipes, I'm confused about which exh kit to buy, it will go through the wall and have a 48 inch vertical rise.
I am looking at this pipe kit on amazon for $300 and winder about the end cap, it looks like its open with just a pest mesh, other end caps point downwatd but this one point almost straight up, what about rain and snow getting in, can rain exit at the bottom via the cleanout T ?
I'm looking at this kit.
Reactions: ARC
That vent ends with a 45° down angle which is more than enough to keep rain or snow out.
[Hearth.com] king PK130 which thru wall exh pipe kit to buy?
Reading through the ad I would say yes and no. It does not say high temperature only on some of them you need the one that is high temperature. Black one would look good on black pipe but clear one looks better on galvanized or chrome pipe. I only use high temperature silicone tape in the house, outside I do not seal pipe with anything extra. The pipes seal enough for outside and it is quicker to take apart without the silicone tape when I do my biyearly deep cleaning. When applying tape cut off around 2 feet per joint. Stretch tape when applying. Tape does not stick to pipe stretching tape around pipe and onto next layer of tape. At least two layers of wrapping from that 2 foot piece. Tape acts like a rubber band and sticks/stretches to itself. That way if you ever have to take pipe off you just unwrap or cut trough the tape and it just comes off with no sticky residue.
500ºF tape below is what i buy.
https://www.amazon.com/Fusing-112-Temperature-Silicone-Electrical/dp/B07BYHBCNZ/ref=sr_1_3_pp?crid=2BEUAVLQ4LBDG&dib=eyJ2IjoiMSJ9.m_vcdQgKW8_BkBNjp9OnuIrRhd30Jcqk01G6iZuDIGSVNhocieSmSYATgZOEBRpGJMVsWWHWEPP7-3UOqk56KAH8YFh2YRDVWrzP8oXDtOqfbwDoMWDnnItBYXaUljlf2p8fGTFOC6S_hwC-wOG7nfNHFskWjsdZ1wY9Y9nnKjQxbhzCx1NMNFgO6F1vSo02jl_r0ktlK6J0-yMUqBrJJ1RmzLeIhIUIgnFIjeJ7o5thyu5bZkjZhlCQu-XyxwkiGzTFus9XqwCg3fP1MmExzK8FCl19VEFoOw7o6HeMblQ.lcxr2rVI8SZrLIgLUrnpRLvYGcabwv4Equg7_9XGJw0&dib_tag=se&keywords=high+temperature+silicone+tape&qid=1760634503&s=industrial&sprefix=high+temperture+silicone+tape,industrial,87&sr=1-3
Reactions: Washed-Up
When you look at the selection you gave us, the top one will work, it is good to 500::F
So yes, it would work
Reactions: Washed-Up and ARC
I read ad 5 times and still did not see that part where it is good to 500F, Very first line in paragraph I must be really getting old. LOL
  • Self-fusing Silicone Tape that does not melt up to 260°C (500°F) making it ideal for emergency repairs for automotive, plumbing, marine, hose, electrical, indoor and outdoor applications.
Ok thanks for the link, I ordered the tape.
I can't afford the exh pipe kit until next month.
I Paid $250 for this King PK130 from a woman who said it started to smoke after 4 good yrs, she panicked and bought a new stove.
But I can't test it until I get the exh pipe hooked up.
Meanwhile I'll give it a thorough cleaning and vacuum everything.
so i took a look at cleaning the pk130.
first thing i pulled is the burn pot, 42 holes, but 14 are blocked with ash .
Seems to me that would cause it to burn rich, less air getting to the pellets.
is this the cause of smoking ? It would be neat (cheap) if it was the cause.
  • [Hearth.com] king PK130 which thru wall exh pipe kit to buy?
Reactions: ARC
For sure. I know with mine the instructions say to clean the holes and they give you an allen wrench to poke with.
I have not done it yet for some reason. You can get a wire brush on a dremel and clean it all up.
Reactions: ARC
That will run your stove for a while. Just remember the igniter
draws 250 to 400 watts to ignite the pellets. It will also safely shut your stove off
and run the cool down
we lose power up in maine every winter, will this ups work for the pellet stove.
I little light on power, but pure sine wave (good). I would lite it manually with that one. You will need to be able to recharge it at the same time you are running. With mine (being bigger watts), I run the pellet stove on it all the time. That way if there is a power outage everything stays the same. Then I need to hook up solar or gas gen to recharge my 12V car battery. If you are running on AC, then on a power outage you will trip and could get some smoke into the room. Do you have OAK (outside air)?
I have only bought the stove so far, its sitting here in the living room, I still need to buy the exh pipe kit.
During power outtage I'd switch over to my portable kerosine heater.
if power shute off, typical here in winter, do I need the UPS , not to run it but just to prevent smoke .?
If the smoke isn't bad I wont bother... I have no experience with pellet stoves.
You should use the UPS to safely shut the stove down.
If your system is sealed (Chinmey) and you use an OAK
(outside air kit) There should be no smoke
Before you install the stove, take it outside and do a full cleaning
Then a test burn to make sure that all is good
