king PK130 which thru wall exh pipe kit to buy?
gerard jones
12
maine
Hi , I bought a king pk130 with no pipes, I'm confused about which exh kit to buy, it will go through the wall and have a 48 inch vertical rise.
I am looking at this pipe kit on amazon for $300 and winder about the end cap, it looks like its open with just a pest mesh, other end caps point downwatd but this one point almost straight up, what about rain and snow getting in, can rain exit at the bottom via the cleanout T ?
I'm looking at this kit.
Reactions: ARC
That vent ends with a 45° down angle which is more than enough to keep rain or snow out.
[Hearth.com] king PK130 which thru wall exh pipe kit to buy?
Reading through the ad I would say yes and no. It does not say high temperature only on some of them you need the one that is high temperature. Black one would look good on black pipe but clear one looks better on galvanized or chrome pipe. I only use high temperature silicone tape in the house, outside I do not seal pipe with anything extra. The pipes seal enough for outside and it is quicker to take apart without the silicone tape when I do my biyearly deep cleaning. When applying tape cut off around 2 feet per joint. Stretch tape when applying. Tape does not stick to pipe stretching tape around pipe and onto next layer of tape. At least two layers of wrapping from that 2 foot piece. Tape acts like a rubber band and sticks/stretches to itself. That way if you ever have to take pipe off you just unwrap or cut trough the tape and it just comes off with no sticky residue.
500ºF tape below is what i buy.
https://www.amazon.com/Fusing-112-Temperature-Silicone-Electrical/dp/B07BYHBCNZ/ref=sr_1_3_pp?crid=2BEUAVLQ4LBDG&dib=eyJ2IjoiMSJ9.m_vcdQgKW8_BkBNjp9OnuIrRhd30Jcqk01G6iZuDIGSVNhocieSmSYATgZOEBRpGJMVsWWHWEPP7-3UOqk56KAH8YFh2YRDVWrzP8oXDtOqfbwDoMWDnnItBYXaUljlf2p8fGTFOC6S_hwC-wOG7nfNHFskWjsdZ1wY9Y9nnKjQxbhzCx1NMNFgO6F1vSo02jl_r0ktlK6J0-yMUqBrJJ1RmzLeIhIUIgnFIjeJ7o5thyu5bZkjZhlCQu-XyxwkiGzTFus9XqwCg3fP1MmExzK8FCl19VEFoOw7o6HeMblQ.lcxr2rVI8SZrLIgLUrnpRLvYGcabwv4Equg7_9XGJw0&dib_tag=se&keywords=high+temperature+silicone+tape&qid=1760634503&s=industrial&sprefix=high+temperture+silicone+tape,industrial,87&sr=1-3
Reactions: Washed-Up
When you look at the selection you gave us, the top one will work, it is good to 500::F
So yes, it would work
Reactions: Washed-Up and ARC
I read ad 5 times and still did not see that part where it is good to 500F, Very first line in paragraph I must be really getting old. LOL
  • Self-fusing Silicone Tape that does not melt up to 260°C (500°F) making it ideal for emergency repairs for automotive, plumbing, marine, hose, electrical, indoor and outdoor applications.
Ok thanks for the link, I ordered the tape.
I can't afford the exh pipe kit until next month.
I Paid $250 for this King PK130 from a woman who said it started to smoke after 4 good yrs, she panicked and bought a new stove.
But I can't test it until I get the exh pipe hooked up.
Meanwhile I'll give it a thorough cleaning and vacuum everything.
so i took a look at cleaning the pk130.
first thing i pulled is the burn pot, 42 holes, but 14 are blocked with ash .
Seems to me that would cause it to burn rich, less air getting to the pellets.
is this the cause of smoking ? It would be neat (cheap) if it was the cause.
  • [Hearth.com] king PK130 which thru wall exh pipe kit to buy?
Reactions: ARC
For sure. I know with mine the instructions say to clean the holes and they give you an allen wrench to poke with.
I have not done it yet for some reason. You can get a wire brush on a dremel and clean it all up.
Reactions: ARC
That will run your stove for a while. Just remember the igniter
draws 250 to 400 watts to ignite the pellets. It will also safely shut your stove off
and run the cool down
we lose power up in maine every winter, will this ups work for the pellet stove.
I little light on power, but pure sine wave (good). I would lite it manually with that one. You will need to be able to recharge it at the same time you are running. With mine (being bigger watts), I run the pellet stove on it all the time. That way if there is a power outage everything stays the same. Then I need to hook up solar or gas gen to recharge my 12V car battery. If you are running on AC, then on a power outage you will trip and could get some smoke into the room. Do you have OAK (outside air)?
I have only bought the stove so far, its sitting here in the living room, I still need to buy the exh pipe kit.
During power outtage I'd switch over to my portable kerosine heater.
if power shute off, typical here in winter, do I need the UPS , not to run it but just to prevent smoke .?
If the smoke isn't bad I wont bother... I have no experience with pellet stoves.
You should use the UPS to safely shut the stove down.
If your system is sealed (Chinmey) and you use an OAK
(outside air kit) There should be no smoke
Before you install the stove, take it outside and do a full cleaning
Then a test burn to make sure that all is good
As Johneh said, you would need to run the stove on the UPS all the time, and be there during the power outage to shut the stove off to do a controlled shutdown. In my case I have OAK, and the stove is in the basement and about 15 feet of rise. I probably have a good draft anyway. I have mine set up as a secondary heat source to run on power outages from 12V. It would be better if you could eventually use your pellet stove on a 12V system instead of that kerosine heater. It would be safer I think. It does take quite a bit of space to have a 12V system. I was fortunate to have a whole room in back of my stove (old furnace room). I wouldn't bother getting a small UPS unless it was plugged into AC all the time and at least 600W. I tried that with a backup UPS, but the UPS failed for some reason. It only had a very small battery in it anyway, and unless I was there within a few minutes of a power outage it would trip off anyway. Make sure to get a surge suppressor and better yet add a 230V one to your panel also.
I don't think I'm going down that path, I have a 12v portable kero furnace in the garage, it uses a car battery on a trickle charger to run it, its way too cluttered for the house.
we don't have any problem using the 10K kero heater its just that the drive to buy kero at the pump is 60 miles but they sell pellets around the corner here. Thats the main reason for the pellet stove.
We're both retired, we stay home all day, the stove would not be lit if we go out.
We are both retired now, and we run our stove 24/7 from some time in
November to the end of April. A safe way to heat if the power goes out, so does the stove
If some part fails, the stove shuts down; If it overheats, the stove shuts down
Just my experience and 2 cents worth
I plugged it in to see what happens, nothing actually.
Power at the plug, power at the fuse, tests good.
Found this.
Found this.
That looks like your thermistor wire tells your stove temperature of fire/stove. Other end should be bolted on box that holds the exhaust blower. Never saw one that short before, wonder if it is hung up on something in the back of stove?
Looking at replacement length 25.7 inches stove is 26 inches wide. Bolts on the exhaust blower box on left side of stove goes all the way to right side. So should have 5 or 6 inches of slack, looks just about what you have in video.
Ya, J9 on the board. I'm not sure why it causes no display if disconnected. There must be a protection circuit in case it's bad or disconnected.
Is that like the ESP probe in a Harman?
