Landmaster UTV?
NickW
2,163
Hodag Country
Anyone have any personal experience with Landmaster UTV's? I'm (not surprisingly) finding conflicting reports online.
I've been watching for smaller "work" UTV's (48-54" wide) for use on the property, no recreational trail riding. Stopped at a dealer about an hour away last weekend when I saw a couple sitting there. One is a Landmaster L4 that fits the bill. 4x4, Kohler 14hp Command Pro, winch, plow, hitch, cab, dump box. It's a fairly basic machine, no heat, not fancy or fast; but should serve my purposes. Brand new 2023 model year for $8500 (absolutely will not haggle anymore, I tried) including the accessories. They said they just want to move it because it's been there so long and the price originally was close to 20k. Next to it was a similar Kawasaki Mule 2025 with no plow, no cab for $9500...
The overall ratings on it seem pretty good (for what it is as a work machine) with cons being "noisy" and weak brakes. Then I found forums with some folks absolutely blasting them (and all off brands...). Complaints about the engine bogging down and running for crap. Then someone chimes in about E85. It's so hard to know if complaints are legitimate or stupid people doing stupid things with equipment (like running E85 in small engines)... Even running 87 octane with the 10% ethanol blend is questionable.
The few similar small used machines that I have found are 6k to well over 10k in varying condition.
Now I know name brand is often the best way to go and if I wasn't a bargain hunter (read "cheap bugger") I'd go Mule, Kubota, small Honda, or something similar; but 15-25k is hard to justify.
Has anyone had a Landmaster with any constructive assessment? There's apparently been some lineup changes recently in 2024.
Why not look at an old CJ5? There are a million on marketplace that run and have a winch for a couple thousand. For 8k, you could get a really nice one that is road trip worthy if you want to do it at 45mph.
Reactions: Dajolu
My neighbor has one that I've worked on a couple of times. His has a Honda motor in it and honestly the buggy as a whole is not really impressive. I'll second the brakes are lacking. The couple of times he's come up my buggy trails with a load of wood it's pulled ok, so I can't fault it at that.
I went through the mental gymnastics you are running through right now when I was looking for a buggy to haul wood around my place. I was watching farm auctions and such and ran across mine in a driveway, for sale. Its a Massimo, read chinessium, made by hisun that is a big builder of that kinda stuff. Parts are readily available and it does the job well. These are the ones you see at Lowes and the like for around 10 k new. Picked mind up for 4k, a low hours steal.
Good luck with your search, I was on the lookout for quite a while.
That's exactly what I tell my wife the people who have the giant machines should do!
Our trails and boardwalks are too narrow for that. I'm currently rebuilding my dilapidated old boardwalks to 64" wide and better framed. I want as much clearance on both sides as possible and keep the weight down which is why I'm looking at the narrow machines.
Massimo! That was another one that was being put down.
My 2 main purposes are wood hauling/work and getting batteries & gas tanks down to the boat/water. There's appeal to a brand new machine with a warranty in the same price point as something somebody has beaten and potentially not maintained.
Flat fenders would fit there.
The overall width of a Jeep CJ-2A is
59 inches (149.8 cm). This measurement is taken from the widest point of the vehicle. Other related width measurements include a track width of 48.3 inches and a floor width of 50.25 inches.
Reactions: Burnin Since 1991
Another option is a fairly low mileage Honda or Isuzu Kei 4WD Kei truck like the Honda ACTY or Subaru Carry. Reports are they make dandy little UTVs.
Well, I pulled the trigger. We'll see if or when I regret it.
[Hearth.com] Landmaster UTV?[Hearth.com] Landmaster UTV?
  • [Hearth.com] Landmaster UTV?
Good deal nick, congrats on the new buggy.
For your future reference the last fix on my neighbor's was fuel system. 30 seconds down the road and it would die. Apparently the fuel line connection on the gas tank isn't well protected from clogging by fines in the tank. Flow was good enough for messing around the property but when the was running hard the flow wasnt enough to keep up. I pulled the gas line off the carb and bumped it with a little compressed air and it was gtg. He had just topped the tank so when he runs it out I'll pull the tank and flush it out.
Reactions: NickW
Thanks for the heads up! I saw there's 2 inline fuel filters but didn't ask if there was one in the tank. We won't be leaving our property with it and the only spot where I can see going full throttle might be coming up the big hill on the trail.
I can see exactly what the reviews on this machine were talking about. Good value work machine not really intended for trail riding. Guessing the couple of reports of poor running are people trying to run E85 in them. I did notice it runs a bit rough when the engine is cold, but that's to be expected for a 2 year old machine with 10 hours on it. The dealer said they did flush the fuel out and put premium in this spring, but that's still too long for gas to sit in the tank. I'll fill it up and run a little seafoam through it.
I would pull the sparkplug too. Figure out the gap and set it .005"-.010" over. Can help the startup and will pull harder at WOT.
Reactions: NickW
