Lightweight chain saw for older user
LAndrim
130
Outside of Philly
Hi All, 75 year old female here. Been chopping wood most of my life. RE: cutting logs, just can't use my older chain saw anymore--too heavy. Can anyone recommend a reliable light weight saw? I need:
1. under 12 lbs
2 something that can handle 10-14 inch logs
3 not electric
Any suggestions would be greatly appreciated!
Stihl MS170
Cheap and lightweight.
We won one at an event, "technically" its the wife's saw, me and the 12yr old use it whenever we are doing light duty wood stuff. Also great to put on the quad and UTV for light duty stuff.
Quick Google search shows that the power head is well under 10lbs, depends on the bar and chain for a final weight, ours has a 16" and it suits it well.
I believe the Stihl MS 170 is no longer made. The MS 172 replaced it. At 10.4 lbs for the powerhead only, it should meet your goal of under 12# even when the bar is added. However, a 32cc, 1.9 HP saw would definitely not be my first choice for cutting 10-14” logs, especially not if they are hardwoods.
In the Stihl line, for a homeowner/landowner saw, I’d look at the Stihl MS 250. At 10.1# and 3.0 HP It’s lighter weight and 50+% more HP than the MS172. It’s a nice combination of light weight and reasonable power for the size wood you are cutting. If your present saw is significantly bigger, it may take a bit of patience and getting used to when cutting hardwoods, but lighter weight does generally have that downside.
A similar Stihl saw is the MS251 “wood boss”. Same power as the 250, but weighs 11# for the powerhead only. For that extra weight, you get their aitomatuc carb (self-adjusts the mixture for various fuel and atmospheric conditions, so no need to manually adjust the mixture). (I’m not really a fan of the MS 251 C-BE. It adds their easy-start system and more weight. I’ve heard multiple complaints about the tool-less chain tension adjustment.)
I’d put a 16” bar on either the MS250 or 251. Many dealers will sell it with an 18” bar. but I find a 16” bar better match for the powerhead only and balance of the saw.
In the Husqvarna line, look at the 450. At 3.2 HP and 11.3#, it’s a little heavier and a little more power than the Stihl 251. I’ve used one in the past and a friend uses it as his primary saw. We’ve found it a reliable saw.
The above are considered mid-range “landowner” saws. They’ll hold up well, if you treat them right. I tend to lean toward the pro-level saws myself. (I don’t cut wood professionally, but tend to be a lot more involved than the typical landowner in my forest management.) they cost a lot more, but tend to have a significantly better power to weight ratio they are also designed to run all day, every day. They are overkill for many users, but if you are interested in hearing about them, I can make some recommendations.
Echo also makes some good saws, but I am less familiar with that line.
Two final thoughts:
1) You may hear from a lot of fan-boys who claim their favorite brand is the only way to go. That is mostly BS. The three brands mentioned above I’ll make some good sauce. They also have a couple of nuts so great, “disposable” saws in their lineup. Unless you happen to be a chainsaw mechanic, more important is to buy from a good, reputable dealer who services what they sell.
2) You probably already know this, but the best performance enhancement you can make on any saw is to keep a good, sharp chain on it. Learning to sharpen is not difficult, with some of the guide tools available. If that’s just not in the cards for you, carry a spare chain or two. Either sharpen or swap at the first sign your chain is losing its edge.
How much are you cutting? I don’t imagine you’ll be cutting all day long, so I’ll put forth a different track of thought.
Years ago I inherited a Craftsman saw that was made by Poulan. It was 42cc and had an 18” bar. It was a bit underpowered with that long of a bar, but it did the job, especially when the chain was sharp. The priming bulb always made starting a breeze. It was super lightweight compared to my Stihl, but the Stihl has a much bigger engine (but I run it with a shorter bar). I ended up giving it to my cousin who lost his saw when his basement flooded.
This is probably the newer version of that saw. It says lightweight, but doesn’t actually list the weight. The thin bar probably helps keep the nose from being heavy. I’m not sure if you can get more agressive chains for it. I’m not sure that that little engine could pull an 18” chisel or semi chisel. Throw a 14” bar on it and I think you’d be slicing through the wood like butter.
I imagine you could walk into any Lowe’s or hardware store and hold one. Poulan used to sell their saws everywhere. It wouldn’t work if you were a lumberjack, but a few hours a day of cutting and it’d be fine.
Second the Craftsman (if you can get it on sale)
I picked up a Craftsman this year that was at a clearance price. Worked good. If you can't get ethanol free gas, and you are only doing small jobs, I'd buy the gas in the cans. Or for big jobs use blended pump gas, then switch to good gas for a few minutes before storage.
If money isn't an issue look for a rear handled MS200 or MS201
Lightweight and good power. The top handled versions are the Arborists first choice for saws to use up a tree because they cut above their cc size
https://www.lowes.com/pd/CRAFTSMAN-18-in-Gas-Chainsaw/5013010821#no_universal_links
They don’t list the weight in the specs, but someone posted a question about weight on that site. The response from Craftsman/Lowes was 15.27 pounds. The answer did not specify whether that was for the powerhead only (which is how most manufacturers specify chainsaw weight) or including the bar. Even if it does include the bar that’s a real pig of a saw. WAY too heavy for a 42cc chainsaw.
They also don’t specify the horsepower. I posted that question, but imaging it will take a few days for them to answer.
I don’t remember it being very heavy, but it was years ago! And a different model, lol.
I suppose OP should walk in and handle some saws. Only she will know what saw is good for her.
I dug out my manual and here is a bit more info. Under 13 pounds without oil or fuel for an 18 inch bar. These are the kind of saws you can pick up on sale. I believe there are ones that come with 18 and 16 inch bars. I like having the 18 inch, as the stuff I was cutting was over 18 inches in diameter. I have a 120V electric for trimming and cutting up branches.
  • [Hearth.com] Lightweight chain saw for older user
Everyone has been SO helpful! You all have given me great advice! I'm leaning toward the Stihl. My Ace Hardware has a few and I'll try picking them up for a weight check. You all have been so kind in taking the time to help. Virutal brownies ( yes, with walnuts) sent to you all!
Reactions: GG Woody
OP, see if shops will swap bars for you. Shorter bars allow all saws to act like they’re a bigger one! It also changes the balance, keeping the weight closer to your body.
Here’s a 14” bar saw at HD. It says it’s 10lbs. Again, go handle the saws and read reviews.
I have this saw. It’s cheap. Light weight. Chains are easy and cheap. It’s not fast. But I’m guessing the OP cares more about weight than speed.
Take the tip guard off. It can cut a 14” log. It probably only has a true10” cut. I can measure it tomorrow if you want. I would not get the 18” version.
Reactions: Whitenuckler
As you are getting older, buy a good quality saw as it will probaly be the last one you buy.
Stihl has the MS150, which i think has moved up to the MS151.It comes in a rear handle version.
It is the smallest Pro saw made. twice the saw of the MS171 which is a homeowner clamshell saw
One of my customers was raving about their battery powered Stihl. Looks a little small for 10-14” logs, but he was happy, and it was light!
Reactions: GG Woody
Not electric was a choice she expressed
Right. Hence mentioning it was battery powered. I saw it there, fondled it, and realized it was really light.
Reactions: GG Woody
When/if my Husky clone 372xp and the dolmar 6400 become too heavy I'll switch down a Stihl MS261 or a similar professional grade echo.
Another thing to consider as you get older is bending over which is why I already use a 28" for bucking duties, especially the small logs near the ground, because I don't have to bend over to make the cut. So any future old man mini saw will be able to run a 28" bar.
First thing to consider is what saw brands have full service dealers in your area. They all need service or parts sooner or later and it's nice to not have to travel far or wait for mail order when you need something for your saw.
Unless you fix your own stuffs
I know for a fact that i would never take a saw to the Stihl dealer here as their rates are worth more than most saws. $150.00 an hour
That’s the standard labor rate for trade work in my area. I’d honestly have thought it’d be higher in Canada dollars.
I fix my own stuffs, but I need stuffs to fix it with and having a dealer nearby makes it easy to get stuffs to fix it with.
My Stihl MS 180 C-BE has done everything I've asked it to do. 32 cc; 2 h.p. Bought it at a place that mostly deals with professionals. Said I have a semi-wooded acre and it's for light-duty homeowner use. They recommended it.
It was branded as a Mini Boss back then. :)
Looks like those numbers are the 172 C-E now, if the Comparison Table on the website is correct. I noticed an error in the listing for the 261 in the table and the book they printed and let my dealer know.
That's sweet of you, but I like Pecans more than Walnuts, in both brownies and firewood. 😉😆
Yep, in these parts you'll drive past a few Stihl dealers before you get to the Husky guy.
