I have a Jotul F500 wood stove and plan on installing a SS liner into my existing masonry chimney that I built about 7 years ago. It’s a block chimney with a clay liner. Metal pipe exits the stove and goes thru the wall for about 28 in. into the flue tile. From there the run is straight up for 23 ft to the top of the house. Chimney is located on the outside of the house. The existing clay flue liner is 8 x 8 with an actual inside dimension of 6 ¾” x 7”. The sales rep recommended a 5 ½ in liner since the room inside the flue is very limited and if I used a 6” pipe I would probably not be able to get it down the existing clay liner. He also said that since the SS liner has smooth walls and because the run up to the top is a good length, going down to 5 ½ verses 6” would be acceptable and my draft would not suffer at all. Makes sense since I’m going from a square clay to a round metal flue. My draft has always been excellent. I have tried contacting Jotul about this but have had no luck. I also will be adding insulation but since a wrap blanket will not fit, I plan on using the vermiculite/cement mix the company sells for this very reason by filling in the space between the SS liner and clay liner. Anyone out there have any thoughts on all this?
