I've about decided for safety and ease-of-cleaning to put a liner in my old clay lined chimney.
I've got an old Jotul 118 and it is currently hooked up to the 8x8 clay lined chimney with 5" single-wall stovepipe. I basically have the chimney running from the basement through the roof and it has two flue pipes in it. One for the Fuel Oil burner and the other is used for the woodstove. As I said, it is 8x8 clay flue pipe. When the chimney sweep installed it, he simply busted a hole in the chimney in the basement and stuck a 'pipe' to hook up the stovepipe to. Then he used some mortar and made the pipe solid in the chimney. That pipe is 5" and has the single wall hooked up to it.
I'm thinking that a 6" liner would do quite a few things for me:
- make it easier to clean, since I would have a pipe that terminates outside the chimney to the stove.
- possibly make the stove a bit more efficient by reducing the draft?!
- make my home safer by having the correct equipment (I have one little girl and another on the way - can't be too safe)
My questions are - should I leave the 5" portion that spans the brick portion of the chimney to the flue? What kind of liner should I get, aluminum or stainless? The stove calls for 6" pipe, I'm assuming 6" liner as well? I was looking at something like this: (broken link removed) but I am not sure why I would need to pay for a Tee when I don't see how I can use it.
Also, I guess you just feed the flex liner down the chimney, attach it at the bottom somehow and also at the top somehow?
Any suggestions would be great - or links to 'correct' instructions. Don't really trust what I find online.
