Log Splitter- Show us your log splitter.
[Hearth.com] Log Splitter- Show us your log splitter.
Not great at small stuff but the 60” maple base I just split in about 10 mins was a lot of fun!!!!
Sent from my iPhone using Tapatalk Pro
Splitter my father in law built for me. New 6.5 hp Predator engine. 5" cylinder, 11 gpm pump. Beam appears to be about 1/4" thickness. It isn't a racer but will split 90% of the wood I have. Splitter ran into a knotted up piece of something and it started to twist the beam, I backed it off and hit it off with a sledge hammer and threw that log aside. The beam untwisted when I reversed the ram, maybe the beam is a bit weak for the power this thing possess? Either way I am happy to have it and beats using a maul.
Reactions: VirginiaIron
Nice. I believe H beams are stronger than I beams. You could stiffen/strengthen that beam by placing plate or U-channel at the base, or stiffeners/plate in the web.
That splitter is a great candidate for a 4” replacement cylinder. No more twisty beam, and 50% faster.
Reactions: Isaac Carlson
Here is a beast of a splitter I just got done working on. It has a wisconsin engine on it. We have a 2 way splitter just like it but with a 10hp vanguard on it. You. An split a lot of wood in a hurry with one.
  • [Hearth.com] Log Splitter- Show us your log splitter.
This is a wood splitter that I built this year. It has a hydraulic log lift system that words great. It has a two cylinder engine that runs a 16 gal. pump. The ram is a 4.5" cylinder. It has a auto return system, this makes splitting go smooth.
marcus
View attachment 251033View attachment 251034View attachment 251035
Thanks for posting. I saw one like this, in yellow, and that unit's lift is actually part of the corner table/working surface.
What does your lift look like?
I was abandoning my idea of another horizontal project for the tabletop version.
marcus
I think that is the nicest looking homemade splitter I’ve seen and you did a nice job on it. Maybe you could open a small factory and give Wolfe Ridge Mfg some competition.
Edit: I think VirginiaIrons splitter is really nice too.
I finally found the tabletop model that had the lift I mentioned. I am very impressed with the design of his lift.
Welcome to the forum, @Damecj! But this is a six year old thread, so you're gonna have to help us out, here. Which "same one"? There were 7-1/2 pages of pictures of log splitters, on this thread.
This revived thread reminded me that I hadn’t found a replacement for my FPE30 25N filter without having to order four. Went to my file, a wood chip with the filter number written in pencil that had been setting on my dresser and online I found 2 cross referenced filters which led to a bunch of more readily available cross referenced options including a Wix that I ordered.
I haven’t been using the splitter much these days but do need to re-split a bunch. Starting more fires with this years warm weather and the mini split pulling its weight.
I have the same one any idea what hydraulic fluid it takes
You can use pretty much anything for hydraulic fluid.
I have ATF in mine as it flows better in the cold.
I have mixed 10W engine oil with ATF and AW 32 in my vintage 950 Cat loaders over the years.
Also running a Wix 51249 filter on my Huskee-branded Speeco. I think it's a very common filter for all mid-size log splitters.
Finally switched my splitter over from the factory hydro oil to all-ATF this winter. Definitely makes a difference.
Actually, I didn't dry-cycle the cylinder. So in reality, I switched 3 out of the 4 gallons in my splitter from hydro oil to ATF. ;lol Good enough.
Reactions: salecker
