j-takeman said:slangtruth said:No, it's properly hooked into the system. I'm a bit sensitive to this because the nimrod who sold us the Revolution made all kinds of noise about how it would heat our two ~1300 sq ft floors with no trouble, and we'd be needing a thermostat to hold it down. Instead, it's proven to be adequate to heat part of one floor to the low sixties when it's not terribly cold out, running 24/7 burning 2.5 bags a day, and can hold that 60 deg through a night like last night cranking at 4 bags a day (ie ~$20 a day). I don't want the guy who started this thread to go off reading about people effortlessly heating their 2000 sq ft homes to 72 degrees on a bag of pellets a day and thinking anything available on the market through the regular channels is going to do the same for his 4-7000 sq ft, or that his fuel costs to do so and the amount of work he's going to have to put in are not going to be considerable. He talked above about spending $2200 on propane, between pellets and the 150 gallons of #2 I've put in for emergencies I expect I'll be paying nearly that much this very mild winter on a much smaller space. Still better than oil, but...if I were the OP I'd be looking at maybe a nice pellet stove in the room where people gather most so I could turn the gas down on a cold night, but wouldn't be looking for central pellet heating.
In my own case, I can't help our building, it is what it is - huge (with 10' and up ceilings) and badly insulated, with over 800 sq ft of window space on each floor. The windows are covered with mylar-type insulation, but replacing them is out of the question (one floor would cost as much as a car), and we can't blow in insulation to the walls, we'd have to remove the clapboards and re-side, which is simply not gonna happen unless I hit the lottery, which I can't afford to playThe oil heat struggles with it, too.
That would have raised a red flag if the oil furnace was struggling. Hard to reduce the heat source volume if the present is just barely doing its job. I'm sure the dealer assumed the oil furnace was adequate. And assuming isn't always good! In your case you might want to look for something thats very close to the oil furnace size. You'll be warmer. Or use the oil to catch u and then go back to pellet to keep up. I would even consider setting it back with a stat, I would think it would be safer to just maintain it at a content level. No setback stat recommended in this case!
Variables always gum things up! But in general a oil/gas furnace that is sized properly. It is generally close to 2x the needed amount on an average day.
The dealer was a living room stove dealer and just wanted to make the sale - he had no experience with central heating and didn't have a clue about what he was doing or what would be adequate, and neither did I. If we change furnaces again I'll look hard at NG, but we're still paying off the Rev and I can't see going with another pellet furnace when it's done. I do use a stat when temps are more moderate, running it at pilot (which is about 60%) most of the time, and cranking it on command for a couple hours in the early morning to get the temps up. I can always burn the dinos for an hour or two when I need to (I did this morning), but I'm trying to avoid it.
I'm sure my problems would be over. I was interested to see that the Fahrenheit owner's manual is almost identical to the Revolution's. Either the same engineers worked on both projects, or they hired the same tech writer and he copied his own work. Check it out sometime.
