I have a fireplace insert with blowers in a brick fireplace with a brick exterior chimney but for some reason I am not generating the heat like I used to in the house. I am using a Quadrafire 5100i, so I know the stove is large enough for 2700 sq ft. The house is 2x6 construction with Anderson windows. I used to be able to cook my self out of the house that I had to open the windows. Even the room that the fireplace is in does not get super hot anymore.
I am using a block off plate (with insulation on top of it) and use a SS liner on the stove. The only thing I can thing I can think of is the high temp caulk started coming out of the space between the block off plate and the chimney. That is only maybe 1/4" around to entire pipe, could I loose that much heat through that little opening? That is the only thing that I could think of that has changed.
Only thing I could think of was adding high temp insulation to the back wall of the fireplace between the insert and the outside wall. Other than that I am at a loss why I am not heating like I used to.
thanks in advance
thanks in advance
