Hi guys!
I had an issue last night with an older stove I've been using the last several years. It's an older Lopi 380, precursor to the Lopi Endeavor of today. It has early secondary burn features, but nothing like what is required by the EPA to-day. I've been burning wood in this model Lopi for at least 10-12 years, never any problems with draft or smoke in the house, except the occasional start-up when it's really cold outside and the stove pipe and steel liner in the chase is super cold.
Well, it's in the '20's and teens right now here in Seattle area, and I had the stove burning all day yesterday, just like normal, very pleasant, maintaining a comfortable heat in the house. Well, around nine o'clock last night, I went to put a couple more pieces of wood in the stove, no issues, but 1-2 minutes after I shut the stove doors and sat down, I started smelling smoke. I went to investigate and couldn't find anything suspicious. I had the secondary burn damper over top the front doors fully open, but couldn't see any smoke coming out. Temperature gauge was reading about 450 degrees Fahrenheit. The smoke smell never went away, stayed all night until I let the fire burn out, it was bothering my wife and daughter, definitely irritating my sinus too.
I thought with all the heavy snow, maybe the top of the chimney was becoming partially blocked by snow somehow, we dont usually get this much up here 8-10". I went outside last night to check, and it didn't appear any snow had formed around the chimney top.
I'm wondering if the up draft was lost some-how when I added wood late at night...if that's possible? Maybe because it was so cold, and my fire wasn't burning hot enough....but even with the start-up damper fully open and the fire really going, it still smelled like smoke. I've got double walled stove pipe from the stove to the entry point in the wall, and stainless steel liner all the way up through a tall chase.
I clean the stove and piping, and chimney liner every other year, usually only burn maybe a cord-and-a-half or two of wood a season. Never any heavy creosote build up, minimal powdery black along the walls. I have some pine that a friend gave me.....I know...PINE....nasty stuff....but I only use it for start-up, and it's been dried by me for 3 years. I switch over to 2-3 year seasoned maple after its warmed up.
i've included some photos to kind of show my set-up. Tall chase on the right is the one the stove is hooked to. I'd appreciate any advice...if we loose power in this storm, I need this stove working.
Thanks very much,
Dow![[Hearth.com] Lopi 380 draft issue... [Hearth.com] Lopi 380 draft issue...](https://www.hearth.com/talk/data/attachments/240/240517-0799e6168261011dd80e76d8a21bc4dc.jpg?hash=AhlApH09ip)
![[Hearth.com] Lopi 380 draft issue... [Hearth.com] Lopi 380 draft issue...](https://www.hearth.com/talk/data/attachments/240/240518-cb665ac3712e9b9bb5af3f31c4722cb4.jpg?hash=JBzvizMcdQ)
Thanks very much,
Dow
