Lopi Cape Cod Hybrid
800 sf with a 3 cf stove? Where are you, in a nylon tent on the North Pole? Must be hard to get wood delivered..._g
Well, there's a little more to it than that, but I'm heating a similar space with a 3.0 cu.ft. cat stove in the other wing of the house. Works perfectly well, thanks to the fact that big cat stove is rated to burn as low as 10,000 BTU.
The space for the new stove is 4 floors netting 1060 sq.ft. each. Take away my 18" thick stone walls, and you end up around 871 sq.ft. interior space per floor, which is not very large. Then consider the fact that I'm heating that mass of solid uninsulated stone all around, including the fireplace into which the stove is set, and heat losses for one floor below the stove and two floors above, three exterior doors and 32 windows in that wing of the house, and the stove requirements begin to climb.
Truth be told, I have no idea what size stove it will take to heat the place, since the setup is less than ideal. This is my primary reason for seeking a cat stove, since they have a much wider range of operation than a non-cat. Go big, and there's no harm in running it low, if need be. If I go non-cat, I'd be looking at a much smaller stove, likely a Jotul 400 Castine.
/\ this makes me want to see pics of your house. Sounds like an awesome place.
It's an interesting place. Lots of fun to heat!
I thought I had put some of these photos in another thread, but can't find it now. Here's some photos from the listing, with the old owner's furniture.
Left end is 1773, middle part is 1894, right end is 1994:
[Hearth.com] Lopi Cape Cod Hybrid [Hearth.com] Lopi Cape Cod Hybrid
Fireplace #1, holding the Jotul Firelight 12:
Living room, showing plaster on stone walls:
Fireplace 2 in original kitchen, shown here with old gas insert, but slated for new woodstove:
Original kitchen fireplace foundation in basement rec. room, will likely receive a direct-vent gas stove (there's already a gas fitting thru the back wall of the fireplace):
Fireplace #4, out on back patio:
I suspect there's another fireplace hidden in the wall of one second floor bedroom, but haven't done any exploration on that, yet. There are four chimney stacks in the house, with five total flues and 7 stovepipe thimbles (two flues have two each). We plan on only running two wood stoves on the first floor, and one gas stove (more for fun than heat) in the basement.
Reactions: charly
Wow the house is incredible but I can sure as heck tell you this.....With that much square footage and the fact that I spied hot water baseboard I wouldn't be messing with freestanding stoves or inserts I would be slapping a big outdoor boiler in with a large storage tank and calling it good.
That's incredible. Every 100 years or so they added on another house. These aren't small additions either. If those walls could talk, just the number of families that must have lived there over the 300 hundred years.
To heat that place with wood will take major amounts of wood. With the sprawl, it will take several stoves.
Wow. Big central wood heater time. Boiler if you have water heat or furnace if you have ducts.
Thanks, guys. You're correct about the hot water baseboard. Six zones. Would be fun to have an outdoor boiler, but obviously a much bigger undertaking. Maybe I could put a wood boiler in the basement next to the oil boiler, down the road, but then I'd need to build another chimney stack. I was already dreaming of putting a second chimney stack adjacent to the oil boiler, if I could talk the wife into putting a wood cookstove in the kitchen above, down the road. Just for fun... and no time real soon.
Woodstoves are our compromise for now, since my wife doesn't want the "mess" of burning open hearths. I grew up in a house with three open fireplaces, and never thought them too messy, but I guess I wasn't doing the dusting. A dual-career family with precious little time for what's really important, our goal is not to eliminate oil completely, but to have some fun with woodburning, while cutting down on the oil usage as much as we can.
One family owned this house from 1773 to 1921, spanning five generations. I've been in contact with some members of that family, although the last generation of that family to live in this house is now passed on, several of their kids are still alive. It has changed hands a half dozen times since 1921.
In this case, the walls do talk... literally! The entire first generation to grow up in this house signed their names in the stucco on the interior face of the chimney on that original kitchen fireplace, sometime around 1775. Some of this stucco was removed to do a chimney repair, and some signatures are now covered by a third floor bathroom addition, but most are still visible in the attic. The builder also signed the same area, and drew some interesting pictures in the stucco.
Now back to your regularly scheduled program... ;lol
Well, that is one amazing place. I love the history. I'm sure that the original family would be so glad that it is still in good hands. So many places like that simply cannot be maintained anymore and fall apart fast. It's hard for us in the NW to identify with that kind of history. Around here, history (other than Native), is 150 years max and not much of that. Pretty much the oldest houses you find around here now are Victorian age houses which are cool enough to be restored a lot. I lived in a house like that in Portland that is maybe 120 years old now, but there are few like that left anymore. So many are beyond restoration which is a shame. We looked at several such places when we were looking for a place and most were just too far gone for us to handle, as tempting as a few were.
Yeah, those Victorian houses are fantastic. Not for me though... too much painting and wood trim rot to deal with!
My family owned the same house and farm from 1692 until 1995. My aunt, the last of my family to live there, has the original Penn's grant to the place, signed 1726... so we were basically squatting on the place 34 years before we owned it! ;lol It was sad the day that sold, but it was an enormous place, and no one in the family had the means to keep the farm going at the time. That was an interesting house, having started as log cabin in 1692, with an early 1700's brick addition, and then a stone addition in the mid-1800's, which engulfed the log cabin. I'm told that there were still original 1692 log walls hiding behind the plaster and lath on some interior walls. They had 180 dairy cows, until the cow plague wiped out most of their herd in 1986, and they decided to retire the farm soon after.
Wow. I love old houses (I hang out on Old House Web as well, under the same SN). We tried for many years to buy several different 1800's era homes but never could get a deal to stick. Yours is fantastic! I LOVE the stone. The last vintage home we looked at was a Cobblestone (it has since become abandoned, we believe the last owner-a man in his 80's-passed away before he could sell it). I was in love with the look, but it was HUGE for us (5 bedrooms), the barn was in bad shape and made conventional financing hard, and it needed a good bit of work. Add in taxes that were near 10k a year and it was too much. The "doors" on the fireplaces are really neat, I don't think I've ever seen that before.
My aunt and uncle had a much smaller house (@2000 sq ft) and they used an add on wood boiler for years. I guess it depends on if you really need all of the house heated at once or not.
Wood cook stove=I'm jealous. I wanted one soooo bad. Then we bought the Cottage and there's NO way one's fitting in my little kitchen!
I think doors on fireplaces were very common, at one time. Bottom line, without refrigeration, there was want and need for frequently smoking meat. Some houses had separate smoke houses, but I believe many of them just settled for smoking in their fireplace, with the doors closed. Most of these big fireplaces have big steel rods running front to back, about 7 - 8 feet off the floor, presumably for hanging meat.
We also had many deals fall thru on many old houses. Spent four years looking, before we bought this one. Almost bought two different old mills along the way, one already converted to a house, and the other abandoned. Both were HUGE (the smaller of the two was 6400 sq.ft.), and each had walls 28" - 30" thick at the ground level. Massive 14" square timbers throughout. One still had the water wheel. Amazing stuff, but no fireplaces! ;lol
Great looking home . . . interesting to read about the history of those places. Old homes just seem to have more of a soul than the new cookie-cutter homes that are being built these days.
Thread is way off track. Closing. The house stuff really belongs in the Inglenook.
Reactions: flyingpig
