LOPI Yankee
howegd
1
NY
Looking for advise on my LOPI Yankee pellet stove. Had a hot igniter issue so I was working on the control board and subsequently fried it. Replaced the control board now it's indicating an electrical fault. The stove turns on, fan kicks on but the auger does not appear to be turning. Any help would be greatly appreciated.
I didn't see a wiring diagram in the above....
You could have a vacuum leak. If you jumper the vacuum switch that will tell you. You must jumper the wires when the power is off, and isolate the jumper from ground.
