I have a smartstove w01. I am having issues getting a ton of heat and I am having issues with coals building up. My wood is dry. My set goes like this
2.5ft 6in double wall pipe running straight out of the stove vertical.
1 double wall 90 elbow
1.5ft of double wall horizontal then goes another 1.5 through my wall as a single wall pipe into a 6in flexible stainless steel liner that runs the length of my outside masonry chimney.
The chimney is 23 feet from where it meets my stove pipe to the top of the chimney. Above the masonry chimney I have a 2.5ft stainless steel extension to get my over the peak of my roof.
The outside air hook up is attached by a 4in flexible dryer vent that runs roughly 10 feet from the outside to the back of the stove.
The two ceramic plates over the burners inside the woodstove are pulled slightly forward to allow more heat to go up the flue. If the plates are slid back blocking the flue but allowing for better secondary burn they stove gets hot but dies out very quickly and I am left with a ton of ash.
My chimney originally started as just a masonry chimney on the outside of my house that ran 23ft and stopped at the peak of the house. The company told me to run a liner and add some pipe to get it over the peak. This has helped but I am still getting a lot of ash and medium heat. I am okay with the heat but the coal is a pain in the butt. Every morning I have to dump 4 gallons of coals.
After I did all this to the chimney the company said i was out of options that's the best that stove can do because my chimney is on the outside of the house and the air is cooling down before it gets a chance to escape the chimney. This has been a 3 month aggrevation and a lot of money has now been put into it. Any help would be greatly appreciated.
. Is there a screen outside?
