We've been investigating wood burning inserts for our fireplace for about a month and I've still got questions without answers and this looks like a good place for answers. First the background, we have a fireplace with a opening roughly 41w x 29.5h, the chimney is about 26' from floor of firebox (done counting bricks...). This is a 30x20 room and this won't be our primary heat source, the heat is nice but we want a good view of the fire. We're looking non-catalytic and have to have large glass areas, we love to watch the fire... Our options so far include: Jotul Rockland CF (or Kennebec CF), Quadfire Voyageur (or Grand see below), Osburn Matrix, PE Neo 2.5 (but smallest of the group), the Nepoleon Oakdale in both traditional or contemporary also look good. All these have been mocked in photoshop and some look better than others. I know everyone has their preferences, but if there's any negatives to any of these I'd love to know. I've also got a few questions...
Several of the surrounds are very close to covering the opening, but fall a little short. The Rockland and Voyageur both would have a 1/2" gap on each side, the matrix would have a gap across the top. I know some folks like a stove in a fireplace, and some have complained a surround lowers ambient heat output. If we don't car about the small gaps, is it better or worse to run an insert with an opening around the brick? Will it affect the blower's performance? Looks like the Voyageur Grand is the same box as the Voyageur with a larger surround, and I like the look of the Rockland better without the extra flat surround behind it.
What is a block off plate used to block off? Is it just to stop heat from escaping or air from coming in?
What is the significance of an insulated vent up the chimney? I don't understand why something which is opened on one end needs insulation around it, and the chimney is outside. We don't valve the top of the chimney, right? (I have the same question about insulated bathroom vents that vent directly outdoors) I know the cooktop downdraft has a dual trap at the end which acts as a dead space at the end.
After reading comments here about the fire's air consumption and negative pressure I started asking dealers about outside air vents. I've been told inserts don't consume much air and that there's no real need. I was surprised by PE's solution for the Neo is to just seal it to the ash vent and seal off the surround. I think I saw that quadra-fire offers a vent, and others here have just made their own. This house was built in 1989 and is not sealed. Dealer said Jotul doesn't have/need a kit. Our HVAC has an outside air vent that's used in the summer, is there any reason why I wouldn't want outside air feeding the stove?
What prevents air from coming in through the chimney vent? When the HVAC is running it draws a lot of air, and I suspect our heating bills have not gone down with this energy star system because we're now pulling in more air than with the previous system. The cooktop downdraft also has a good draw. I don't see why theses won't pulling air in through the insert. Is there some sort of valve/damper that will be a good seal?
That's a lot of questions, so I'll stop there for now.
