Loud blowers PE super insert
Gearhead660
1,246
Southern WI
So, have had a couple fires now in the newly installed Super insert. The blowers sound louder than I think they should be. Almost like a metallic grind sound. Was thinking the bearings could use some lube but they are sealed bearings. Anyone else have this issue? Do they sell just the bearings?
The bearings themselves would make no noise unless they were bad. Since they are new, it is unlikely that the bearings are bad yet. Could be a mounting issue, or out-of-balance. This could lead to a bearing failure due to vibration. The only other way to ruin a bearing is heat.
There is a possibility the bearing(s) were damaged when they made the blower. If you can remove it, then run it on the bench.
The insert is not new, its a 2010 model. The bearings/blowers spin fine, just seem louder than they should.
I know what you mean. You really need the blowers on in an insert though. I have two blowers in my pellet stove, but again I can't do anything about it except turn the room blower speed down.
The blower should be reasonably quiet on lower speeds. Make sure fan cage isn't rubbing. @Dix has this insert for a sound comparison.
No bearing noise on my PE.
I had to replace the fan assembly a few years ago due to a shorted power cord (operator error :mad: ). Wasn't a complicated thing to do.
I'll try to get a video tonight when it's running for a sound comparison for you.
Reactions: Gearhead660
Hope this works. First time ever posting from my phone , lol!!
*Edit* looks like you have to open it in media player :)
  • IMG_1157.mov
    14.7 MB
I tried troubleshooting a blower noise issue last year. Used a bit too much 3 in 1 oil and house smelled of it. Got some inexpensive new blowers and was much quieter. I told myself to just get new next time if troubleshooting took more than a bit of time.
Reactions: Dix
Thanks Dix. Sounds like it's purring like a kitten.
Thanks! Yeah, that sounds much better than mine. Might just need to get new blowers.
Reactions: Dix
If it has standard ball bearings on each end, I don't think you can re-lubricate them. They are packed with "lifetime" grease and then sealed.
If the bearing and seal have gone bad, then they need to be replaced. Replace the blower, and then you can work on the defective one. The bearings themselves are only probably only about a dollar each, but you need to take it all apart and get a puller. I would do it as a project, but I like that sort of thing. If a user manual says to add oil to a sealed ball bearing, let me know, as I'd like to check it out.
It does. Usually on a very low setting ;)
I heart this stove like whooa , to quote the cowgirls 🐴🤠
