Hello
So now what? Re-Tap!
Total cost of the repair is $2.76 for 2 Stainless Steel bolts at Lowes!
This will be the first time on a tractor.
So I checked the bolt size and if I went up to a 5/16-24 with the fine threads it would fit but I would have to ream out the steel washers in the bench vise with a titanium 5/16” drill bit.
Ok, now I can try out the new Harbor Freight SAE titanium nitride tap & die set!
See vid of the issue
Pic 1 - original bolts and washers
Pic 2&3 - new stainless steel 5-16”-24 x 1” long from Lowes
Pic 4&5 - Drilling out original steel washers to 5/16 inside diameter for new larger bolts
Pic 6,7,8 - New Titanium SAE nitride tap & die set from Harbor Freight.
Pic 9&10 - using 5/16” tap with Rapid Tap lubricant
Pic 11&12 - It worked!!
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298697-a7a1a743fd6b6572e7f4bcc22a83a299.jpg?hash=LAWeZFHcCg)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/styles/default/xenforo/clear.png)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298678-9f01592fd8823c0b6813acd896c8d423.jpg?hash=puomBjSHR-)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298679-ec9f6952fc8a467faea4fcfbece4928c.jpg?hash=YTOaWTLew1)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298680-40ea160250e302479abd548377b8a996.jpg?hash=UHjXKe1e1a)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298681-ae7a7f6ab5936aa78ad2a564c8996ffc.jpg?hash=uQRjFUbJNr)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298682-4a7728dfca7bab51c693eb6915d929c2.jpg?hash=3oXoCVhlNf)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298691-069ac05164ca934fc02d973e15ef529b.jpg?hash=BrQtDDCjHc)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298692-cb4e256ac779269fe48ccf61ffe7f014.jpg?hash=91VGjxzSB-)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298693-066546e674e450677e31b64de6213465.jpg?hash=x9A5O7RBJi)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298694-2da4f24ff379305fbf1bc6dc1966374f.jpg?hash=reXYbc5d3L)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298695-45007ae3fcd8fddbd2af741919ba9fe7.jpg?hash=OmqnL6hyLi)
![[Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose! [Hearth.com] LT1000 Sears Craftsman 42” tractor gas tank bolts stripped and loose as a goose!](https://www.hearth.com/talk/data/attachments/298/298696-b307ae2777811a3bc685d2dc051a1f4e.jpg?hash=giq2mXVcXt)
