maintenance advice for me? Thank you!
Courtney
54
Westminster, MD
Good afternoon everyone, I am now the proud owner of a second quadrafire Santa Fe. My small Maryland rancher now has one (first one 2 yrs ago) in the finished basement and a new one on the first floor, and I am off the grid and loving it. I am vested in taking the best care of these stoves and had concerns for best performance.
I have no problems with either one, and maintain them over and above the usual schedule - clean daily, complete vacuum weekly. Clean ash pan 2x/wk, clean feeder monthly. PM once a year by technicians prior to shut down. I run both on high right after cleaning for 30 min to keep creosote down, but they usually burn 24/7 on low occasionally med. Temp set at 68-70ish. Using Penwood pellets (new to me, the old ones were mixed soft/hard and I liked them, but they were dc'd). I do not like the Penwoods so far (1 ton) they burn with lots of tough clinkers, may upgrade to Henry County?,,, Will burn 3 tons this year but maybe 4 next.
Questions
1. I have not had the chimney cleaned on the first one. The new one is too new to need it. The techs that do the pm would be ideal, but they don't usually do that. Should the chimney be cleaned yearly by a chimney sweep professional now that I will rely on these exclusively? Should I do it myself? Dont want to damage anything, and want it done right.
2. The basement one burns more than upstairs in that basement is below ground and cooler. Heat moves upstairs on a temperate day. It maintains on low. Upstairs kicks off frequently because of that now it is early spring. I think because of this I may be concerned of creosote build up on this one. Is running on high each day enough to cure that concern or should I be worried about build up?
3. Opinion on pellets?
Long post, apologies. However, when I had no heat for 10 days and it was 9 degrees out, the downstairs unit saved our butts, as did the kind responses and support from this forum. Many thanks for that!
Hello
Those Santa Fe's are great units! I have 2, one in my shed and one in my garage! I also just picked up a Contour which is the older Sante Fe with the Pie Warming compartment in the top!
When you say chimney in question 1, does it have a liner? If it does then the stove techs should brush it out.
Describe the venting on your basement stove. It would be helpful to know more to answer your questions.
I think hardwood pellets work well.
Hello
Liner on both standard install. 5' rise to outside with 12 inch lateral run to outside vent which is 18" above ground level on basement stove, 14' above ground for upstairs
And Thank you!
You can clean all the venting yourself. I like the "sooteater", it is a simple design, fairly cheap and works great. This kit will clean the liner and the vent pipe off of the stove. And yes clean it at least every year. With this kit it is very easy, do it often and avoid problems.
And how to purchase? Thank you! Do you advise a do it yourself or professional? How frequent if using 24/7?
It sounds like you only have 6 feet of pellet pipe, not a lined chimney. If that is the case, it would be quite easy to do yourself, especially if you have a cleanout T at the bottom of the 5' vertical pipe.
Yes, thank you. What do you recommend for a newbie to do this?
No pics and it never happened that's a rule;)
Welcome to the show Courtney
? What pics do you want? I don;t have anything to post here?....
Do you have a cleanout T?
Not quite sure what that means. Some of our experts will show up with an answer soon:cool:
I believe they do the overall clean out but do not clean the pipe, confirmed . I am not at this time ready to do a second run thru after paying a lot to do a basic pm . Advice? Better to diy or pay for service? Many thanks!
If you are handy it is very easy to do, what did they charge you?
Here's a pic of my stove [Hearth.com] maintenance advice for me? Thank you!
Nice unit Will.....
Welcome Courtney. Santa Fe is a solid unit and should last a long time.
As for Creosote. List of things have to go wrong to produce Sote in a pellet stove in only run my Quad on Low and have never had a problem. Just nice grey/white ash.
It sounds like your doing pretty good PM's. The vent can be easily done yourself with a pellet vent brush, or the Soot-eater, or Lint-eater. Pretty straight forward.
Welcome to the Forum, and pics are always welcome (pics of your set-up)??
