Yeah that sounds like a pita will go back to burning wood be fore doing all thatI looked into it and it seemed more hassle and expense than it was worth. First you need the pellet mill, then you likely will need a hammer mill to grind your biomass fine enough. Then you need a source of clean biomass and lots of free time to grind up the raw materials, get the moisture content right and then run that thru the pellet mill. After that the pellets need to be stored on racks or some other type of homemade dryer for drying. Then you screen them to remove fines and finally put them into storage.
