When I sit and watch my stove I swear i can hear my room blower motor changing tunes and tones on the same blower speed. Ussc ashley 5660l. Does anybody else notice this or am I mental
Could be your imagination. What you hear is most likely the harmonics of a shaded pole motor.
Funny you mention this, I swear the radio is on in the other room playing Led Zepplin...When I sit and watch my stove I swear i can hear my room blower motor changing tunes and tones on the same blower speed. Ussc ashley 5660l. Does anybody else notice this or am I mental
Yeah. Not quiteFunny you mention this, I swear the radio is on in the other room playing Led Zepplin...
Is the noise really annoying or is it something just noticeable when everything else is quiet
Always manual.LordmetalZ28, are you operating in M or T mode, I have never ran mine in T mode, I have always been running mine in M mode (manual) when I hear that split second motor speed up. Don't quite understand how T mode works, so I don't go there.
If IGuys, this is not a feature of the stove. If you were to plug the blower fan directly into a wall outlet you would hear the same thing. Believe me I know! I went through two control boards with mine because static electricity was taking them out and as a result I built my own controls. Even after this I had the same issue with the fan so I added a rehostat to slow down the fan when on high just a hair and the noise went away.
I guess If all of the 5660l are doing this its not an issue and I wont worry about this until the day the motor dosent turn. Then its time to burn that cheap natural gas up.Guys, this is not a feature of the stove. If you were to plug the blower fan directly into a wall outlet you would hear the same thing. Believe me I know! I went through two control boards with mine because static electricity was taking them out and as a result I built my own controls. Even after this I had the same issue with the fan so I added a rehostat to slow down the fan when on high just a hair and the noise went away.
