Hello guys,
I just ran across this forum and gleaned some really good information. I would like to start out by saying thanks for any information I get and I hope the noob doesn't drive you nuts.
So here is my question:
My stove is really old and says "Portland Furnace CO." which I cannot find any info on for the life of me. The stove has tons of air leaks around the doors and the air vent is a small circular wheel and is completely useless; it has another large chamber above it which I think was installed to reclaim heat. The exhaust is just forced to run a long course before it goes out the stack (makes it smoke when I load it) It can hold 26-28 inch logs and is about two feet high or more inside the box; the stove itself is round like a massive looking barrel but is a very thick grade steel. It has absolutely no seals in it at all. I can load it totally full and after sitting four 7 hours or so all the wood is gone even on low. So I thought about buying a new one. But before you answer let me give you a little interesting picture (in your head) about the setup.
My house was built in 1972 and has three wings, all wings meet in the middle and have open ducts running from the middle of the home (which is a large area dedicated for the stove and water heater) to all wings. The current setup has a lot of masonry bricks to form a octagon shape in the middle of the home for the fire place. This thing is probably 8.5 ft high and 200 square feet. The wood fire place is in the front section of the masonry with only the access door showing from the outside of the bricks for wood loading. The heat stays inside of the room which gets really freaking hot
!! this in turn gets transferred to the bricks and it radiated for hours on end.
So my thought was initially to buy a Cat stove but after thinking will there be enough heat transfer to keep this room warm? Soapstone is out of the question because of price and weight even though the middle of the home is concrete. I thought a non-cat might work but it seems everything requires power now. The current stove might need renovation and somehow seals made for it, the nice thing is that it radiates a lot of heat without power. It just burns up a but load of wood and we did get it dampened down once and it sucked on heat output. Sp Maybe a new style furnace is in order. Here are my thoughts.
1. Max Caddy (lots of power usage though and loud)
2. England furnace (smaller but less noise and less efficient too)
3. Canyon™ ST310 (large stove and a non-cat stove. puts out alot of heat and looks like it will radiate without power)
Here is a basic floor plan of the house with a picture showing the location of the stove in the middle. Let me know what you guys think and sorry for such a long winded explanation.
