looking to finally make a purchase am would like some input as to what folks find useful and bang for the buck. Thanks in advance!
I just got one off amazon, I see it's on back order but it seems to work well. For what we are using them for, I don't think you need to spend a lot
http://www.amazon.com/Meter®-MD-812-Display-Digital-Moisture/dp/B008V6I840/ref=sr_1_3?ie=UTF8&qid=1419980256&sr=8-3&keywords=moisture meter
$20 to $30 I think is fine. I used the heck out of mine the first year.
Now I know when the splits start shifting in my stacks I am to about the fiber saturation point, ~30%. Until then I don't bother with the meter because I know everything is >30%.
The hard part for me is leaving the tool in the garage when I am out by stacks on the hot sunny days.
With a couple seasons of experience, ehh, I could probably do without out it and guess pretty good, but all I have to test up here is birch and spruce. If I were to move to the lower 48 I would have to start all over again learning new species.
What's the fiber saturation point? And how badly do your stacks shift? I just finished building a stack of shagbark hickory which after I was done I realized was somewhat on a slope. A shift in the wrong direction may start a topple in a year or so. What would you say is the percentage of shrinkage (length and width) of splits from green to seasoned?
$30 bucks, lowes, general......seems to be very accurate for me....
Is the sale at lowes over? They may be 20 bucks instead of 30 if you get it before end of day tomorrow at lowes
The foresters up here generally say 18% "radially and tangentially" when talking about spruce and birch. Above the fiber saturation point you got water coming out of the through and through tubes, the wood doesn't change shape. Takes about two weeks up here (when we are getting 16 hours of sunlight daily).
After the water is out of the tubes, you are at fiber saturation point; as more water comes out the individual cells are drying and splitting open and changing shape of the split. That's where the stack gets to moving, generally at about 30% MC for most species.
Mine shift pretty bad once they get to moving, and I got a bunch of twisty splits this winter, so my pile will probably be moving a lot next summer...
Very informative thanks! It would be interesting to see a time lapse video of how a stack moves around throughout the process. Some may equate it to watching paint dry, but morbid curiousity has me thinking...
So splits won't loose any in the length at all then? Or only marginally which would hardly register.
I saw a $20 moisture meter at Lowes today, but online reviews of that model were very poor and it was the only one they had with pins. It also looked like the pins were out the back and not out the top. The pins were barely about 1/4" long.They did have one without pins but I didn't think that would work well. Any other meter suggestions besides the one at Lowes?
It was a General meter, but you are correct, it was not the one that folks here recommend. The Lowes.com web site shows they have the recommended model at my local store, but I was told they no longer carry that model. The local Lowes is a smaller store, I will check at a larger Lowes and see if they have it.It wasn't the general meter that a lot of people on here recommend then.
