more chain advice - husq 435
onetracker
606
rondout valley ny
so i go to the local shop where i've bought a bunch of stuff over the years. great guys there...family bussiness since 1937.
i want a new chisel chain for this 435. 16"/.325/.050/66 drive links. they make the chain there while you wait. fits fine but one tooth jams up behind the clutch cover. i figure its a bad link where they joined the loop. tech spins me another one and its not as bad but still locks up on one link only.
advice?
btw - its got a raker and a bumper plate. isn't that safety chain?? i wish i got the model number. i can't stand safety chain.
OT
Look closely at the rivets on the link that hangs up. They'll look a little different than the other links if it's the link that they installed. Is it possible they assembled the chain using 3/8" parts? Sometimes 3/8 can look similar to .325 and I've corrected more than one rookie parts guy from handing the customer the wrong chain.
Raker and a bumper plate = Safety chain. All chain has a raker in front of the cutter unless someone has ground it off. If it's the humped drivelink style of safety chain, it's not intolerable and should cut pretty close to standard chain until you get the nose of the bar buried.
thanks MM. its definitely only on ONE LINK so its got to be the spot where they joined the loop.
