I have a Morso 1125 stove that I recently got (obviously) used. I am having trouble with it running too hot. Now, I know that the handle on the right door controls the incoming air and controls the heat. But my question is: to run cooler, do you open or close the flue damper? I thought to run as cool as possible you closed the front door as tight as possible and closed the flue damper. But, I am wondering if that is backwards, and closing the flue damper is my cause for it running hot. Can some one tell me which is right? Does the closed flue choke the fire, or hold the heat inside?
! Anyway, thanks for all the help, it looks like we finally got it running as it should. It's nice to sit at home with it 40 degrees outside and be comfortable in the stove room and not wake up every 3 hours to add 3 more logs!
