So, what is this white rope that is in the bag that came with the insert (5660)? I don't think it is a gasket, but don't know what it is! Don't see a reference in the manual. Thanks~
being sucked on by a very efficient 6" flue (They use 5" in Europe). As installed with leaking pipe joints my stove would either burn fast with the air at least 1/2 open or, at 1/4 open, the fire would go out because the primary air stopped flowing as the leaks and those *%$# secondary air holes let too much air into the flue. I sealed all the joints (which all showed creosote inside where the cold air was entering) and can now run the stove with just enough primary air to keep it healthy. With everything sealed (and the secondary air inlet half blocked
) I get a 2 hr+ burn and keep the glass clean as opposed to 45min burns before sealing it all up.
![[Hearth.com] Morso elastic white rope in kit [Hearth.com] Morso elastic white rope in kit](https://www.hearth.com/talk/data/attachments/149/149214-bc3e680688c0194736f5ed4483514d26.jpg?hash=XnGeeTCJ33)
