I'm aware that fans help with moving heat.
But I'm wrestling with trying to get the second floor a tad warmer while using a stove in the basement (two floors down). The physics of rising heat has me confused.
The stove faces the stairway leading up the basement to the main floor which is in the center of the house. The stairway up to the second-floor bedrooms is directly over this basement stairway. Such that the ceiling to the basement stairway is slanted because it is below then upper staircase.
I thought I had a brilliant idea to install a grate in one of the risers in the staircase between the 1st/2nd floors. Then, I installed a grate in the ceiling of the staircase between the 1st floor/basement. The ceiling grate is almost directly below the riser grate.
For the amount of heat that one can feel rising up the basement to 1st floor staircase, it is disappointing in how much escapes through the vents.
What do I need to do to get the heat to rise through those grates?
