How are you cleaning and maintaining your deck? (Lots of rain here this year so mowing every 4 days)
Blow off with leaf blower on top. Putty knife on bottom. Not fun.
I've heard good things about Fluid Film but have never tried it.
Have one of the those.Water fitting on top of the deck.
interested to hear your take on them. i got in a discussion with a john deere employee, and his final words were "well, grass has moisture anyway, so if you don't use it, you're going to have moisture held in by grass you couldn't get!"Keep using those wash out ports....... Daddy needs a new truck!![]()
Wash ports are a double-edged sword at best. The problem isn't when the blades are running, it's when they stop. The spindle assembly cools, creating a slight vacuum inside and unless your spindles have good double-lip seals in them, moisture will find its way in for sure. Also many spindle units have a cup of some sort that is to protect the bearing seal from debris that wraps itself around the shaft. These will get paced with dirt and grass in short order and then they are perfect for holding water directly under the seals.
You can counteract the damage by greasing the spindles often. And only using water to clean under the deck when absolutely necessary. After you use water to wash the machine off, you should grease each fitting to flush out the water.
Wash ports on. 21" walk-behind mowers are totally legit however.
use silicone spray or the dry slide by PB blaster both seem to help as long as you start clean
cheers
What is this cleaning you talk of?
I pull it out and clean it all out every couple years. along with sharpening the blades. I only mow about 4 acres for 4.5-5 months though.
I am on at-least the 8 cut this year so far and with all the rain so far the wind rows just dont look right. Kind of like a sweeper thats just not working right. (35 cuts is average for my area per year)
I just rebuilt the deck spindles on my old John Deere STX38 last month. They were DESTROYED.....had a fun time taking them apart. I'm convinced that the reason they went bad is because A) they have no grease fittings on them and B) I used to wash the underside of the deck after every three or four mowings. Haven't done that in years, but the bearings were wore out. I scrape the deck once or twice a summer now, especially since I just put new bearings in it. I've already had to weld a couple patches on that deck and also do some tweaking to the lowering arms.......but she still cuts like a dream!
Haven't cut any grass yet, maybe in the next week or two will be the first mowing.
After you paint it all up, use the fluid film. It helps. I use it on my commercial mowers. It's not an end all solution, but it sure helps keep alot of it from sticking. Reapply it every month or so and all is well. On your tractor, use a set of car ramps and you dont even have to drop the deck. The spray cans are pretty pricey for what you get, so I buy quarts and use an old paint brush to apply it.
FWIW, it works pretty darn good on snowblower chutes too.
I've never cleaned a deck. Never had one rust through either. What does this do for you, the guys at work say it helps the suction and the bagging work better?
I did accidentally clean the bajeepers out of the deck underside once. I chipped several trees/branches onto the lawn and cleaned the piles up the best I could. The remaining smallish 3/8" chips were then sucked up with the mower. Wow did that ever clean things out. It was like a bead blast.
I suppose I shoudl have then coated the underside with some sort of oil or paint. Can one apply used engine oil for this purpose? I need to change the 16 quarts in my ford soon.
