MSRP vs street price
Bunsen
18
Hi folks! I just began looking into replacing the Scandia 900 that came with our house and hasn't been used by us. The terracotta in our exterior chimney is cracked and needs to be lined, but can't fit the 8" steel liner that this stove requires. The stove is also not in great shape so we're OK with getting a newer nicer one.
It's been suggested to us that putting in a 6" liner in with a new stove will only cost a bit more than sticking with our current stove and paying for the labor and materials to break out the terracotta and install an 8" liner, so I'm looking into this option seriously. It means we get a new stove AND a new liner!
Now I'll get to the point... in most of my other interests, from guitars to photography, there is a large gap between MSRP and actual price in stores. I'm trying to figure out if this is true for wood stoves also but haven't had much luck. Specifically I'm looking at the VC Resolute-Acclaim, and the VC Encore.
I don't think I've mentioned yet that I have almost no wood stove experience, and I'm just starting to look. I've chosen to explore these two models because of their size and look more than anything else, but I'm more interested in the msrp vs street price question. If it's relevent, I live in southern new england.
Thanks for any help you can offer.
Hi and welcome. The stove market is different, but in someway similar to cameras. You will be hard pressed to find great bargains when a new hot model camera is released because demand is high. Similarly, right now is peak stove selling season. Bargains may be around, but they are nothing like you will find off season. Still, there are lots of good stoves out there and you might want to look at other stove models so that you stand a better chance of getting a good deal and possibly even a better stove.
BG makes a good point, theres so many stoves out there you may be happier with something else, maybe give us the size of your house, layout, is this your main heating source and you can get some ideas from everyone here.
As far as price, stoves arent like cars, what the price is on the sticker is what they want, sometimes you can get a deal if you have them do the whole nine yards, stove, install and liner.
Thanks for the replies guys. It's helpful to know if I should expect any bargaining room when I finally go to make a purchase.
This stove will be going in our living room and will not be used as our main heating source (we use natural gas for that). I'm expecting to use the stove as supplemental heat and for the cozy atmosphere, but expect that this may change once I start using it. I wouldn't be surprised if I start using it a lot more once we get used to using it. In any case, I'd like to be able to heat the first floor of our home which is about 550 sqft. with 9' ceilings.
The hearth our current stove sits on is only 40" deep, so I need a stove with a tight back clearance in order to have enough space in front of the stove for code (our current stove does not meet code because of this). The rear wall of the hearth is also brick.
As far as money goes, I'm trying to not go broke on this project. I think the cheapest option is to order a 6" lining kit and install it myself, then find an affordable used stove. Otherwise, spend a bunch of money, hope to get a nice Christmas bonus this year, and pay a local business for the whole package (liner, stove, and install). I really hate to go this second route, but I also hate dancing up on the roof. I'm handy enough to do the work, but would feel like a cheap jerk if I ever hurt myself working way up there instead of just paying a pro.
Let me know your thoughts and if I've forgotten anything that would be helpful to know. Thanks!
Howdy and welcome. Couple of things that would be most helpful would be for us to know where you're located (indication of the climate/winter temps we're looking at), and a couple of pictures of the stove location, plus maybe the chimney from the outside...like that. Rick
In additions to pictures I'd like the full dimensions of the hearth area and distance from center line to nearest combustibles if they are close.
It's too dark out to take photos of the outside chimney, but here is a shot of the current stove location with dimensions. For location, I'm not too far from Providence, RI, on the MA border. Hope this helps. =)
Today I spoke with a salesperson who suggested a Lopi Republic 1750 because it has a really tight rear clearance (4.25"). I think it still wouldn't leave enough room in front, but I was surprised to see such a large stove with such a tight clearance. I've been looking at small stoves hoping to make up for the shallow pad it will sit on, but a lot of smaller stoves would come to about the same front clearance because they require 9"-10" rear clearance. They quoted me just under $3400 for stove in basic black, double wall pipe, thimble, 25ft 6" liner kit, install labor, and tax. They also will throw in a blower for "free". It's a lot of money for me, but I didn't think it sounded like a rip off. Anyway, thanks for the help guys, let me know your thoughts. =)
[Hearth.com] MSRP vs street price
The Jotul Castine is pretty shallow. Do you have full brick on the wall? If so, for some stoves that might get you a 33% clearance reduction.
I would get the right stove and extend the hearth if necessary. Note that single wall pipe to mantel clearance is supposed to be 18". I'm guessing that is more like 3-4"?
Do you need the liner? Whats the chimney like now?
begreen, those are full bricks, not just a facade. I am honestly not sure how much clearance there is behind the brick. I had the Jotul Castine on my list of stoves to investigate, but I haven't yet. I know they can be pricey. I'm really trying to not extend the hearth if possible at all. The room is only 12' wide here, and the current hearth already occupies a good chunk of that. I understand it may come to this, but I hope not.
Dill, I do need a liner, that's how this whole thing started. My original post explains those details. :)
mellow, no it is not electric baseboard, it is forced hot water from our NG furnace.
Cheers
Regarding the Lopi Republic, I looked at it closely when I was shopping. I'm pretty sure it's the closest rear clearance stove out there (that I saw anyway). It looks like you will almost certainly have to extend your hearth in front, no matter what you get, so IMO, you may as well figure on getting the proper size stove you need for your house, climate, etc. Forty inches isn't going to cut it for any stove I know of. However, you may (probably) only need to provide a simple ember protection in front of the existing hearth, and that may only be about 8" (or less with the Lopi - maybe only about 5") and could be very simple to do with one row of tile. BTW, Lopi gets good marks here.
You will find the advice you need here regarding models, installation needs, etc. Lots of knowledge and experience here.
My price here would have been about $3200 installed with tax (no hearth pad), but my installation is different. Your quote seems right in there to me. Unfortunately, this is not the best time of year to get bargains, but it never hurts to try.;)
Depending on the stove, you may be able to extend the hearth at floor level with simple ember protection. This is the case with the Lopi 1750. The extension could be just a sheet of metal.
Note that there are shallower stoves. Drolet has several affordable models that are wider than deep. The Englander 17VL is only about 12" deep and about $650. It depends on what the goal is here.
Will the mantel get a heat shield on the underside?
Thanks begreen, that is something I'll seriously think about. By my calculations i need an additional 3.75", so maybe I can get something on the floor to surround the current hearth. The real trick will be to find something that looks nice and doesn't stand out too bad. As easy as it would be to use some sheet metal, I don't think my better half would let that fly.
If the brick on the back wall counts as a protected surface, AND I use the double wall pipe, can I get any closer than 4.25"? The salesperson I spoke to said it's a possibility, depending on the surface, to have the stove hug the wall. This would be ideal for me as long as it doesn't burn the house down. The salesperson only mentioned that it was a possibility, not that it is likely...
FWIW, I think you could have the liner professionally installed and stove connected for about $1200-1500 and you can have a Drolet, Napoleon or an Englander delivered for a grand or less. The more I think about it, for this small area the Englander 17VL might be a nice fit here.They are sold at some big box stoves or can be ordered directly. And it would need no hearth modification.
http://www.overstockstoves.com/50tvl17--epa-certified-noncatalytic-wood-stove--1250171200.html
PS: The metal extension could be copper or some other interesting metal. It could also be a nice tile border.
Unless you can walk outside and see the same brick you're seeing from the inside, you have to assume that brick is against combustables, and does not qualify as a protected surface. A "protected surface" typically implies a metal heat shield with 1" or greater air gap behind it.
The possibility exists of finding a cheap jerk to get on the roof for you in exchange for hot chocolate and chili.... Worked for me.
Love ya, Hogz... ;)
That is not quite correct. NFPA 211 guidelines permit varying degrees of wall protection depending on the material and design. Metal does not have to be involved at all. A 3.5" thick masonry wall achieves a 33% reduction.
Now your speaking my language! These bricks happen to be 3.5" thick. That can help with my front clearance.
However, for the 17VL there is no need for the additional reduction.
I need to look into this stove, but I'm pretty excited about the Lopi now. It's always dangerous for the rational side of my brain when I get excited. It also doesn't help that the salesperson told me today he may be getting a less than 1yr old Lopi Republic 1750 in on a trade from a local woman who decided to remodel. He's going to call me when he had numbers for it.
I discussed the hearth with a friend at work who is handy, and we came up with a few ideas on how to tastefully get some more front coverage. So I think fitting the larger stove isn't too big of a deal now.
Love ya, Hogz... ;)
Good point. I'll ask around :)
My local stove shop sells these black hearth extenders in different sizes, not sure what they're made of but they were relatively inexpensive and looked good, in the spring you just pick it up.
Thanks weatherguy. That's actually one of the ideas that we came up with. At the very least this would be useful to pass inspection if we can't get a permanent solution in place by that time.
