Purchased a house built in the 70's, which has a beautiful masonry fireplace in the center of the house, located in the living room. The stone on the wall and hearth were harvested from the property while the foundation was being dug. This stone also covers approximately 60% of the outside of the house as well as the top of my chimney.
I had two dealers stop by and I didn't get a very good feeling about either of their install capabilities. So after much looking on this forum, I've taken the deep dive on installing it myself.
First thing I needed to do was have a new crown poured on my chimney as the original crown was in disrepair. I hired this out as I'm already pushing the weather's timeline and I'm not experienced with concrete. This ran ~$900, which included a chimney sweep.
After the sweep I proceeded to rip off the existing doors and start grinding out the damper and smoke shelf. Couple things I learned here:
After the grinding, we performed a final clean on the stone. I fabricated a metal bottom for the insert to slide on to make installation a bit easier.
Final picture is of the stove set into place. I had to grind a couple of the stones for it to fit, which was emotionally tough to do, but I think it looks alright.
I haven't received the liner yet (more on that to come). Once I do, I will fabricate the block-off plate, install the liner and fire it up!
***And yes, before I fire it up I will update the ember protection to meet code and the manufacturer's recommendations.
![[Hearth.com] My DIY install - 5100i and Forever Flex Hybrid [Hearth.com] My DIY install - 5100i and Forever Flex Hybrid](https://www.hearth.com/talk/data/attachments/162/162873-1ed05ec2e45fd90e18ecd3f9a1e5f4b3.jpg?hash=71EMTcZQCR)
- Milwaukee Diablo metal blades for a reciprocating saw work amazingly well. Highly recommended
- Used a plastic shroud around the fireplace opening to keep dust/creosote at bay
- Use a redneck fan at the top of the chimney to draw a draft to evacuate said dust and creosote
