You replace the whole unit $500 and two hours of labor and tax.Dang.
What is the design of the charge port latch that makes it $1000?
Looks like a proper 500 amp cable assembly.You replace the whole unit $500 and two hours of labor and tax.
It’s has plastic locking tab that comes up from the bottom.
Probably. First generation S and X were limited to 150kw. I’ve seen some posts of unsustained 175kw. Sometimes used onboard chargers are sold with the charging port as removing the charge port cable from the onboard charger damages the tamper proof stickers.Looks like a proper 500 amp cable assembly.
I know you like that car for what it is and it seems to really fit your needs, but if I had a car that needed as much service as you describe, I would never buy that brand of car again.Driver side Fore and aft control arm bushings failed $2k
Charge port latch failed $1k…..
Rear large drive unit (when they can get one delivered) $0.
Exactly.I know you like that car for what it is and it seems to really fit your needs, but if I had a car that needed as much service as you describe, I would never buy that brand of car again.
Oh I would never spend my money on a Model X. But if you are offered a used one as a gift you say thank you! and enjoy it even though it has reliability issues. I’ve learned a lot. Remember it was this technology that was the proving ground for the Model 3/Y. The 2019 update of the S/X is better better.Exactly.
I'm learning quite a bit here.
They have changed a few parts and changed the rear suspension some. Recalled some control arm that had casting flaws. It’s better but it’s what you get when you want to share a lot of components between two platforms. The front suspension was never designed to have the ride high of the X so they eat front CV joints. 24k miles on my first set. I can feel vibrations now are the toast not yet at 50k. I’m more careful now to lower the suspension when I want to stop on the go fast pedal.Agreed that zero purchase cost makes a difference, and I have also read that the mistakes of the early Model X in terms of undersizing the suspension and other components for the high weight of the car have been largely solved.
