karri0n said:From the vid, it just looks like the chain is dull. If it's making dust and not chips, you've got an issue. No offense intended here at all, but my Poulan went through wood that size faster when it still had the safety chain that the previous owner abused the hell out of. I have a semi chisel oregon chain(13 bucks) on it now and it would eath through that wood in less than half the time of your vid. I do think you would enjoy cutting a lot more(and be safer) if you got a new chain. I used mine all season and haven't taken a file to it, and it still eats. I will need to learn to file sometime soon, though.
Yup, you're right. All of them on that side of the chain are the same. I hit a rock, hmmm, sometime last Spring I think. Should have seen it right after I hit the rock! I always keep a new chain, sprocket, and bar on hand. Won't use it though until this one is done, maybe another year in it.blades said:in the chain pic your cutter towards the top of the page has its leading edge(point ) rolled over if the others are similar ,
I saw the thread. I was going to try to make it, even though I already had plans to attend an astronomy class at Wildcat Sate Park that night. But, now it doesn't look like I will be able to make either one. My replacement for milking the cows that day fell through on me.blades said:Hey Quads go to the Wisconsin get together 9-19 just outside Madison, shoot now I do not remember the town. There is a thread about it here somewhere.
The one in the video always did run bad compared to the other one I have. The other one always revved higher and ran better, until the running lean problem developed. It was my favorite saw. It has the high speed mixture adjustment, which the one in the video does not.billb3 said:I have an 026PRO and it revs a LOT higher than what sounds like in that video.
So I've heard, but I'm the exception to that rule! Ha ha! I have never been able to do it right with a file, for some reason I really screw it up. I gave the file up 5 or 10 years ago and I'll never try a file again, unless someone comes along that can give me some proper instruction and show me what I do wrong.geardoc said:Try hand filing your chain instead of the dremel or electric sharpeners. It will cut and last way better...
After the tornado I really had to watch for limbs and whole trees under a load. Some of the cutting was tricky, but when the loggers went through it with their harvesters they took care of most of the dangerous stuff.savageactor7 said:My least favorite part of the process is limbing...concealing leafs and limbs under load.
