Hello All, I wanted to thank everyone here for all the advice I had gotten over the last few years. I was hoping to help someone else with the story of how I found affordable heat.
My search for affordable heat started when I bought a 2800 sq. ft. home away from natural gas lines. The house has 2x6 walls but cathedral ceilings throughout. It has a large open foyer that makes it difficult to save money by selectively heating sections of the home.
The first year I kept the house around 65 when occupied and 58 when away. We burnt 1100 gal or oil and 100 gal propane (stove in FR) that year. In short, we paid $4500 to be cold and it was on average a warm winter.
The next year I convinced the wife to purchase a Harman XXV. It replaced the propane stove but the location was not ideal to heat the whole house. It is a long rectangle and the XXV is in the narrow end of the rectangle and it is a bit difficult to get the heat to the far end of the house. We kept the stove on 24/7 and set it at 70 when occupied and 65 when unoccupied. We burnt 6.5 tons of pellets and 460 gal of oil for a savings of about $2000. The ROI would be 2 years. The cons were the heat distribution, filling the stove (2-3 bags a day), cleaning the stove every weekend and the dust (from cleaning, scraping clinkers and filling stove w/ cheap pellets). This was a good solution when comparing the pros and cons.
That winter I decided to research on replacing my oil boiler. The efficiency after a cleaning was 77%. (also has a power vent so that eff. is much lower in use). My wife insisted that the boiler would be low maintenance (filling/cleaning) and I was looking to save money. I was looking at outdoor wood furnace and oil, propane and pellet boilers. The oil and propane boiler would have minimal cost savings. Wood was going to be too much work and I would have to buy wood. That left the pellet boilers. Out of all the pellet boilers I researched I really liked the Windhager BioWIN series of pellet boilers. They automatically knocked off the ash from the heat exchangers. It has an auger system that moves the ash into an ash box which can easily be removed and dumped the ashes every 2-3 ton (the BioWIN tells you when it is time). This unit is it will modulate its heat output from 100% to 30% meaning it will adjust the size of the fire to your house’s needs this increase the efficiency by decreasing that amount of starts. It also monitors the temperature of the exhaust gas and cuts back to avoid losing heat up the chimney. The unit is robust enough that you can change between different types of pellets without any manual adjustments.
Our plan was to keep the oil boiler as a backup (we also were worried only having a pellets boiler may scare off potential buyers when we decide to sell the house) and go all out on the pellet boiler system. We replaced all the piping around the boiler. We also added a Turbomax hot water store. This is reported to increase the efficiency of the boiler by not having to turn on and off as frequently. I am sure we could get a whole thread on the subject of pro and con but pragmatically it stores the heat so all the zones have instant heat while the boiler is starting up. It takes about 15-30 minutes, I think, for the boiler to get up to full output, so the instant heat works great. I also have a 4 ton bulk pellet storage that feeds into the boiler. For all that are interested I bought this from Vermont Renewable Fuels. I know when I see quality steel work and they sell a great product and have great customer service.
The boiler is using fewer pellets than I had originally anticipated. My daily average is 57 lbs for Nov., 85 lbs for Dec. and 100 lbs for Jan. When I was only burning oil, I used 4.2 gal/day in Nov. and Dec. and 5.3 gal/day for Jan. and Feb. Prices vary but if you assume $250 a ton for pellets and $3.90 a gallon for oil I will be saving somewhere between 6 to 9 dollars a day. So with all of the add-ons in my system the ROI should be less than 7 years. Our house is now comfortable if not on the warm side and I do not have to daily scrape clickers and fill pellets. Cleaning and filling is now reduced to 3 - 4 times a year. If anyone has a house that you cannot get a pellet stove in a central location and you are looking for something automatic and simple to use you should look into a BioWIN. I cannot say enough good things about this boiler, it is great.![[Hearth.com] My quest for inexpensive heat. [Hearth.com] My quest for inexpensive heat.](https://www.hearth.com/talk/data/attachments/126/126162-55e33eb00a27ea659a048bf4477debfc.jpg?hash=dW7KF34o1J)
