Out of the blue my 1980's Whitfield 1 distribution fan began sounding like an unbalanced washing machine in spin cycle. It had always run at maximum speed, I believe because the control setting dial inside the variable-power unit (rheostat) was set wrong, producing little if any reduction in speed. I removed the blower and gave the shaft some lubrication for the heck of it, but the squirrel cage was noticeably wobbly, so for sure a bearing to two must be shot.
I have limited options since I can't find any reference on the internet to the Fasco motor that powers it. [No. 7021-7462 Type U21B 1.65 Amp.]
I hope another motor can be attached to my blower housing somehow, though I have no idea how to separate the two.
I read about imbalanced blowers and mine is definitely now imbalanced since it's rumbling sound is very rhythmical, so for the present I'll remove it once more and attempt to balance it, if possible.
I adjusted the rheostat speed-control dial inside its control box too far toward the slow side so now it either runs fast or runs slow, and the in-between is limited to the width of a hair. Running slower quiets it down a lot, -as I learned when bench-testing it with a variable-power controller, but that was before adjusting that dial too far. I'll have to find a happy medium so I can use it during the interim.
While running it today, and sitting next to it with the blower apparently running too slowly, the entire stove just shut down. That worried me but later, after cooling, both blowers worked again. Lesson: higher speed keeps the heat down. I'll aim a fan at the back inside next time.
I saw at a road-side rummage sale location an old Whitfield model, -but more modern than mine, but it was in horrible looking condition, -exposed to an old barn environment it appeared (very dirty) but priced at just $50. I'll check it out tomorrow and maybe pick-up such cheap spare parts, -heck, I might even end up with some to sell and pay for the thing! That would be a great silver lining. Now if only I can figure out what the heck to do with my over-flowing septic tank here in wonderland.
