My trailer rebuild thread
Keep in mind if you add a second axle you will need to move the first one. The two axles will need to be centered over where the existing one was. Also you will need a load equalize connecting the two axles, otherwise one axle will always get more of the load depending on the terrain etc and inevitably you will overload one of the axles and blow a tire of break the axle. Lastly, you would really need to beef the frame up a fair bit before it would make sense to put on a second axle. I wouldn't trust that frame with more than 2,000lbs MAX. Honestly, as an upgrade route I would suggest getting a welder to add some more lateral bracing to the frame and gusseting where necessary, then put in a new 2,000lb axle and run 12" or larger wheels. Ideally 13" because then you get into a lower pressure (12" wheels normally take 90psi, 13" normally only 60psi) which is a lot easier to fill.
Your best bet really is to just to keep doing what you are and clean it up and use it as is, should be a nice trailer as long as you don't over load it.
Thanks for the offer bob. I'm gonna see if I can get these bushings in if I throw them in the freezer for a while
Joe- thanks for the tips. In all likelihood it'll remain single axle as long as it serves it's purpose alright for me
Just finished the last coat on the frame and the wheels. As soon as I get the bushing issue figured out ill be on to re-assembly:cool:
[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread
Got the leaf springs bolted in today and the wheels bolted to the axle. Tomorrow ill bolt the axle up and put the fenders on and then its on to the woodwork!
Well the trailer is on it's own weight again. Got the axle back under it and also painted the wooden frame in hunter green. Tomorrow the fenders will go on as well as the wooden frame and ill cut a new 2x4 to square up the front
might be an idea to run your trailer wires now through the frame , or make sure the wire has plenty of holding points for it before you cover up the deck , but starting to look good .
Reactions: n6crv
That would be a good idea I just don't have my brake lights yet haha. I got the wooden frame bolted in and squared up. I'm measuring for the decking now. It's starting to look like a trialer again!
Looking really good!
Will be a spiffy addition to your wood hauling :)
Thanks bogy!
Got a lot done today. After the frame was bolted in I got all my 5/4X6s measured out and painted. I got all the stakeside pockets screwed in as well. The left side and tailgate are done and are easily removed using the corner connectors:cool:
Some pics from todays work:
[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread[Hearth.com] My trailer rebuild thread
The sides come up 17 inches
Almost ready to rock & roll.
Nice job on the sides & squaring it up.
Almost done! Finished putting in all the sides this morning. All are removable except for the front. Decking is layed out and just needs to be screwed down
Got it loaded with wood today? :)
I have one that needs some TLC like you did to yours.
Rusty & some decking need replaced.
I put a few of these "d-ring" ties downs on at various locations.
Come in handy when hauling misc stuff.
link: D-rings
have them on utility & ATV trailer, on the boat, shop wall.
Handy to have something to tie to .
Yep I got a dozen of those at harbor freight. They'll be going in once the decking is finished up
Looking good. Just be careful of those tall sides. Like I said, 9" tall load of oak in there and you will be at capacity. If you load it to the top of those 17" sides with green oak you will certainly break it.
That said, it really does look nice. Also, did you have to get new bushings or were you able to the ones you thought were the wrong size?
Yeah I'll be mindful not to fill it all the way with wood, it'll be used for hauling scrap as well so the taller sides will be handy for that, along with any other miscellaneous yard trash/crap that needs hauled.
To get new bushings I would've been in about 40 dollars on 6 90 cent parts so after the freezer and a little dremeling the ones I got went in. If they fail down the road then ill get new ones but it seems like theyll do alright for now. I even went to a local trailer parts store and they didn't have a bushing big enough for my leaf
Thanks joe and will do.
It survived its maiden voyage! Granted it was just carrying a mower a blower and some gas but it didn't explode so it was a good trip haha. All that's left is some little things to button up: trim the rear edge of the decking so the tailgate will fit on, add d-rings, and paint
Reactions: joecool85
A few little updates from today...
Since this trailer will be used for my handyman/landscaping jobs as well as firewood gathering I added some touches to make it better suited for that duty
Ladder rack on the side: bungees down and locks to the stake side with bike cable
Extension cord hooks:
And I got the d-rings installed for tie down points, 4 on each side and 2 in the front corners. I have 2 more for the rear but ill wait until I get the brake lights mounted to see where there'll be room
Sorry about the sideways pics my phone isn't cooperating
  • [Hearth.com] My trailer rebuild thread
Looking good, but do the extension cords just sit on one hook each? If so I'd be worried about hitting a bump and losing them.
They do. I considered that as well but it's a tight fit to get them on and the hook curves back over the top of the cord if you get what I mean. The cord slides into the hook moreso than it just rests on it. I may take it down my road over the speed bumps to see if I can knock them off but I think they're on tight enough that they'll stay
Yeah, I agree on the testing over some speed bumps. Just do it when there isn't much traffic :-)
Reactions: geoff1969
Looking good.
Multi use trailer.
Should last many seasons ;)
