Nashua nfp-1
shw
2
indiana
Hi All.
I have a Nashua NFP-1 and have a few questions.
1. On the door gasket. The gasket on the top and sides is good and appears to be about 1/2 inch. However there is no gasket on the bottom of the door. The channel looks much bigger, about 7/8 inch, and deeper. 1/2 inch is much too small. The door seals pretty good at the bottom without a gasket but I assume one is needed.
Does anyone know if there should be a gasket in the bottom channel and if so what size?
2. Does anyone know if a blower is available in the aftermarket. I've made one work but would like to have a OE fit.
Any help is appreciated.
shw
  • [Hearth.com] Nashua nfp-1
It might be 7/8"gasket all around. Contact Woodman's if no one chimes in with the correct gasket diameter.
Here is some info on the blower motor:
This site sells them. Be sure to match the flange size. They may also know the gasket diameter.
