Does a tstat count as gear?
Anyway, I have this thermostat at the river, which has been great. I use it to take the chill out of the air when I go down with the wife and kiddies (usually I keep the temp at 42' when I'm not there) before I get a chance to fire up the stove. Problem is that the heat pump always wants to crank up the aux heat when warming up from that temp. I disconnected the aux heat, but would like that functionality if needed. Is there a wifi thermostat that would allow me to either a) manually control the aux heat or b) allow me to have more control over when it comes on (ie, only if the set temp is > 15 from actual temp, or whatever).
Second question:
If I can find a suitable replacement tstat, I'm going to move the above to my main house. Mostly heated by wood, but esp if I'm out of town, I'd like to control the gas. I have a standard A/C unit and a 2 wire gas furnace with radiator heat. Currently 2 thermostats. I'm re-doing the furnace wiring (getting rid of some knob and tube) and would like to consolidate the 2 stats. Seems like all I'd need to do is share the R terminals between the furnace and air handler and use the W terminal for the furnace. Don't think I'd run into any issues sharing an R terminal, but wanted to check. This would also give me a C terminal for the gas furnace so I can stop using the fu#$@ng batteries...
Second question:
eneral.pdf)
