I'm remodeling the fireplace wall my Gas insert stove was in and have some questions I need help with. I'm keeping the stove as it's only 4 years old (Travis Industries 33DVI). As you can see it is a lava rock wall and full length bench that was previously hidden behind drywall. I decided to rip out the bench in front of the fireplace and remove the tile surrounding the fireplace. The way the lava bench was framed out was pretty rough, it was pretty much a bunch of bricks and cinder block thrown together and covered with the lava rock (when I say throw together I mean it in a literal sense.) When I removed the bench portion directly in front of the insert I noticed the contractor did a rough job of framing underneath the floor of the fireplace (as seen in the pictures) my first thought was to pull out the blocks and clean up the framework than I got to thinking why not just take the whole bottom of the fireplace out and actually re-install the gas insert on the ground. This fireplace is in a daytime basement so it has a concrete floor. I know I might need to have the gas line extended and the intake and exhaust hoses lengthened but is there any reasons why I couldn't remove the floor of the fireplace and mount the insert on the ground? I like the idea of mounting it on the ground because my end goal is to build a mantel and mounting a TV on the wall above the mantel and I figure the lower the fireplace is mounted the farther the heat will be away from the TV. The last pic closely represents what I want the finished product to look like.
![[Hearth.com] Need Advice on Remodel Project [Hearth.com] Need Advice on Remodel Project](https://www.hearth.com/talk/data/attachments/283/283935-e413f23e85670de4a617bec828e27931.jpg?hash=Y4i59Ovwc0)
![[Hearth.com] Need Advice on Remodel Project [Hearth.com] Need Advice on Remodel Project](https://www.hearth.com/talk/data/attachments/283/283929-74f3512dcd605e6962be8cefe9d1dda3.jpg?hash=bwKKFcS4mj)
![[Hearth.com] Need Advice on Remodel Project [Hearth.com] Need Advice on Remodel Project](https://www.hearth.com/talk/data/attachments/283/283930-e9092ba1390425514ef4094d7f55c106.jpg?hash=rWlPaRE40g)
![[Hearth.com] Need Advice on Remodel Project [Hearth.com] Need Advice on Remodel Project](https://www.hearth.com/talk/data/attachments/283/283932-34d962e5994343d93e0af2970b88ed9e.jpg?hash=L0oxhcRP4p)
![[Hearth.com] Need Advice on Remodel Project [Hearth.com] Need Advice on Remodel Project](https://www.hearth.com/talk/data/attachments/283/283933-d3a86a72a74a8111c9bc5aa2eab21343.jpg?hash=tCgYHSQWAV)
![[Hearth.com] Need Advice on Remodel Project [Hearth.com] Need Advice on Remodel Project](https://www.hearth.com/talk/data/attachments/283/283934-66b8b601dddfd44a7e64ee9eb3d117ed.jpg?hash=rWq1xRs-lb)
