I doubt an Englander stove this old has a lid switch. I bought mine in '08 and it didn't have a lid switch then.
Mine is a "10" and does have the lid switch, might want to make sure the switch is deactivting when closing the hopper lid.
) Having the proper model number and year of manufacture really helps in finding replacement parts, and accurate help. These things are pretty generic though.thank you all so much for you help.
I will get the floor fire proofed with some brick and run it tonight and let you guys know how it goes.
Even a sheet of steel underneath would be better than nothing...
From the manual:
FLOOR AND WALL PROTECTION
Floor Protection
If your floor is constructed of a non-combustible material such as brick or concrete, there is no
need for floor protection. If the floor is constructed of a combustible material such as hardwood,
linoleum, or carpet, then you will be required to use floor protection between the unit and the
combustible. The protection should be U.L. approved or equivalent (ULC if Canada) and must be
large enough to provide a minimum of one inch (1.0”) behind, four inches (4.0”) on both sides of the
stove and at least six inches (6.0”) in the front of the unit. This floor protection is intended as spark
and ember protection only, therefore it need only be non-combustible (there is no required R value).
As briansol mentioned, hopefully you have a wall thimble and appropriate venting. Is there a Habitat for Humanity Restore (or similar) near you where you may be able to get the appropriate materials... I know some jurisdictions will help out with heating requirements for those that are in need (Erie County in New York had a voucher system).
