Getting ready to cut a hole in the wall for thimble. Was going to run double wall so at least 9" from ceiling. Question is where I'm installing the chimney looks like will be maybe 4" away from the direct line up of chimney possibly. Is the double wall stove pipe maneuverable where I will be able to adjust it to reach the stove correctly or is it imperative to line the chimney up correctly. I know people replace stoves and the footprint could change correct. Should I go lower down and run single wall instead?
Or do I not stress it and install the chimney where i can mount between studs and the double wall can be installed and adjusted to work regardless
Thanks
Thanks
![[Hearth.com] Need help before cutting hole for thimble [Hearth.com] Need help before cutting hole for thimble](https://www.hearth.com/talk/data/attachments/317/317454-29405b7a5a6147401ec4891ab67a326a.jpg?hash=TrNkjt5UYq)
![[Hearth.com] Need help before cutting hole for thimble [Hearth.com] Need help before cutting hole for thimble](https://www.hearth.com/talk/data/attachments/317/317462-69616769a2b59665bca99f39234e178d.jpg?hash=qjOZEGMh7j)
![[Hearth.com] Need help before cutting hole for thimble [Hearth.com] Need help before cutting hole for thimble](https://www.hearth.com/talk/data/attachments/317/317470-c065cf2f0afb2528076bc2df0d43daa1.jpg?hash=Q5ZL8GxHRs)
![[Hearth.com] Need help before cutting hole for thimble [Hearth.com] Need help before cutting hole for thimble](https://www.hearth.com/talk/data/attachments/317/317471-4df7afef00818b98e0f5c91c0e7ac253.jpg?hash=IHbBfn9IbA)
