We are building a new home and want to start out with an efficient source of heat. We have trees on our acreage and like the feel of wood heat, so have decided on a wood burning insert. After many days researching, my head is spinning and I need some direction.
Our home will have the insert placed on an exterior wall in the family room. The family room is in the back of the house and is open to the kitchen and breakfast area. The entire area measures roughly 900-1,000 square feet. The overall plan is not really open - it is a colonial style with a two story foyer. The living and dining rooms are in the front on each side of the foyer and the family room and kitchen/eating area in the back. All upstairs bedroom doors open to the foyer. The total house size is approx 4,000 square feet. There will be an HVAC unit for each floor located in the attic and crawlspace, both centrally located. Here are my questions:
1. From what I've gathered, a block chimney with special grout is fine and doesn't need to be lined with fire bricks as long as I use an insulated zero clearance liner. A pre-insulated stainless steel liner is a must for code and to acheive proper drafting. Is this correct?
2. Since the family room will most likely get very warm, I could use the HVAC fan to move air around the house. Since this is a new build, I can have the HVAC installer place intakes where I want. Would having the intake in the family room be the best location? Lower wall or Ceiling placement? I'm confused on this since some of the insert installation manuals I read online state that intakes should not be near the unit.
3. I was told by wood insert dealers that a large unit like the Quadra-Fire Voyageur would bake us out of the family room area. They said we should go smaller. Is this correct or could we just build smaller fires? I've read two groups of thoughts on this - one says it's not good to under utilize an insert as the pipes will not be as clean, others say it's fine.
4. Costs online are all over the place. From the quotes I've gotten, the builder says it would run $6,000 to build the masonry fireplace. The cost of inserts appear to be around $2 - $2,500 for the units we were looking at and the insulated flexible liner was quoted at $1,000. This brings my cost to roughly $10,000. Is this about right, or am I looking at higher costs?
5. We have looked at the Quadra-Fires, Pacific Energy and have just heard about Jules. We have friends with QuadraFires and liked the performance, but are not sure if they are the best for our situation or in general. Since the home is colonial, looks are important and we like the looks of the Jules and QuadraFire Voyageur. Do you have suggestions on which brands have the best reputation to help narrow our search - the choices are a bit overwhelming.
I hope I gave you enough information. Thank you in advance for your help.
uide/detail.aspx?id=97)
