Hello,
I have a sauna stove getting installed in an 8x6 shed and I'm responsible for buying the necessary parts. The details:
Thank you!
![[Hearth.com] Need shed stove install advice [Hearth.com] Need shed stove install advice](https://www.hearth.com/talk/data/attachments/287/287055-1d9e536b48ce485751631b1959d35f80.jpg?hash=v09oTRaOwV)
- Harvia 20 Pro sauna stove - 2.5ft tall on 2 inch pavers
- 6" pipe - the stove is coming with an adapter from metric
- Floor to cathedral ceiling is ~8'
- Roof pitch 5/12
- 12 inches to wall on all side
- What length of stove and chimney pipe to buy? Does the chimney pipe come through the ceiling support box? By my calculations I have 5.5 ft from the top of the stove to the roof, so do I need 4ft of stove pipe and like 6ft chimney pipe? Does it come through the support box or can they only connect in the box?- EDIT: I think I can solve this by just buying a telescoping pipe. I'm still not sure on how tall the chimney pipe needs to be though.
- I'd like the stove pipe to be single wall and the chimney to be double or triple. I've heard double walled all the way in a sauna can affect heat output. I guess I'll still go with double but curious.
- Does the ceiling support box need some sort of non-combustible insulation around it or just a gap of some sort? I've seen it with and without insulation.
Thank you!
