While looking into upgrading our old woodstove, we learned that we need to make some changes to our current setup to meet codes and for safety reasons. We have a chimney through an interior wall. The chimney consists of 16" square concrete chimney blocks with a 6" terra cotta flue running through it. Our problem is this: our wood studs and drywall are too close to the chimney/terra cotta thimble. So, we need to tear down what we have and rebuild the wall to different specs. That's fine but I can't seem to find exactly what those specs are. We are also considering using a Saf T Thimble in the new construction to help reduce our clearances behind the stove.
My questions:
1) How far must our studs (wood) be from our concrete chimnney blocks and is that distance needed on all four sides of the chimney blocks (front, sides and back)? Is it 18 inches from the nearest edge of the unexposed flue on all four sides of the chimney or 18 inches from the chimney block itself? Or is it something completely different?
2) What about metal studs? Are the clearances the same as with wood studs?
3) What is the best non-combustible wall covering product to use in place of drywall?
4) What about the Saf T Thimble? Do they work as well as advertised?
We understand the clearances from the stove to combustible materials, so that's not a problem. Our problem is with understanding the requirements for the framing around the chimney and the material on the wall, especially around the thimble. Our stove pipe goes into the wall behind the stove, not the ceiling.
If anyone knows of a diagram on the Internet for interior wall chimney framing, I would really appreciate the link.
Thanks!
Mike
My questions:
Thanks!
Mike
