New Construction with Drywall Fireplace
MO-Ted-T
3
Missouri
I am building a new home and have a drywall (type x) and 2x4 framed "fireplace" and chimney out through the roof.
The builder seems to think I can put an insert in.
I would like to put an insert in.
Talking with the mechanical (HVAC) contractor and he has concerns about installing any woodburner inside of a non-masonry fireplace.
New to all of this, have been a lurker, but relatively new poster.
Thank you in advance
Definitely can't put an insert in that space
Reactions: NickW
Each ZC has specific requirements to it for installation for clearance to combustibles. You may need to rip out some framing and drywall to properly install. I needed steel studs above mine for a minimum set distance and drywall is not non-combustible. The requirements for a "fire wall" between an attached garage and house are not the requirements for a fireplace surround. Flue support and fire blocking are something else to look into...
In order to discuss options, we need a lot more details about what is currently in place including dimensions. Please post some pictures too if possible.
