A new cat is going to burn a bit hot. It will break in and settle down soon.
Right; Give it a week or so and you'll probably see cat temps moderate a bit.
But I've run three different brands of cat stoves, and all of them were capable of glowing the cat brighter than I really wanted to see it. A general rule I operate under is "If you want something to last longer, run it easier."
Another way that you can slow the cat down a bit, if it's pushing toward 1600, is to run a small amount of flame on the wood. Flames will burn some of the gasses before they can reach the cat, so it won't run as hot. But adding air to get small flames, you may also get more wood burning which would release more smoke, and when you cut the air back to get a cat-only low burn you might be back in the same boat with a hot-running cat. You'll just have to experiment. As I mentioned, top-down starts might be another way to flatten the curve of smoke release at the beginning of the load, if that's when the cat is going high. Bigger splits also burn in a more controlled manner than a bunch of small ones, which ignite faster and gas more at startup.
Now, the IS tube/cat hybrid is different than the straight cat stoves I've run, so I don't have those additional insights. Obviously the tube flames are going to eat smoke, as flames on the wood do...
If you continue to max out at 1400-1500, I wouldn't be concerned.
idealheat, I hope you report back with an update on your burns and cat temps. I'd find it interesting. 😀
			My cat gauge shows numbers. I watch everything but I also know that the BK instructions do not prescribe actions based on cat temperature beyond the active line.
Oh, yeah, I remember now that you finally
did switch out their stock probe to one with numbers.
As for BK instructions, I'm not surprised that they don't mention high cat temps. Their general approach seems to me to be "Don't concern yourself with details, we'll run your stove for you as much as possible." They may also believe that the less people get involved with their stoves, and the less they know, the fewer questions they'll ask and the less confusion there will be. So they give you the thermostat and the numberless thermometer.
Now, Beth(?) at Woodstock also told Pigeonman "the internal cat probe reading was insignificant" but it's unclear whether they were talking about high cat temps, whether she was telling him to close the bypass based on stove top temp, not cat temp, or what..?
But I'm something of a detail guy, so I want more info (to a point.) My quest for cat info led me to articles by the combustor makers themselves, and they talk about excessive combustor temps over an extended period as a source of potential damage. I'd trust what those folks are telling me, more than I'd trust what BK is
not telling me.
			I have found no color to temperature correlation as you describe. Sometimes it glows immediately after engagement at 500 sometimes black at 1400. I don’t have the problem of the cat glowing so brightly that I can’t see the cells. Maybe that’s a buck issue?
Well, I did have an issue with the Buck 91 that I didn't have with the Woodstocks or the Dutchwest; With those, I could kill the flame burn and cat burn by cutting the air all the way, on the Buck I couldn't. I was in the process of adjusting the air intake covers to fit tighter, so that I
could cut the air low enough to kill the burn, but my MIL moved and I never got to implement that. I'm pretty sure it woulda worked, though.
Other than that, I don't think there are any "stove maker issues"  determining how brightly a cat will burn in a particular stove. If you feed a cat a lot of smoke, it's gonna glow brightly. After all,
all of these ceramic cats were made by Applied Ceramics, out of the same materials, and displayed the same characteristics regardless of the stove they were in. Even the steel cat I had in the Dutchwest at one point reacted similarly...ALL of them started to glow at around 1000* and got progressively brighter, the hotter they got.
Now I guess I'll have to drill a hole in the top of the Keystone and put a probe in there to verify that the same thing is happening, thanks to
your contrarian arse. 😆 The probe hole on the Fv and Keystone is in the back, and the probe needed is so long that the cat temp can't transmit all the way back to the dial. Or I guess I could feed a digital probe lead through that hole.. OK, I'm a little off track here, sorry.. 😏
Regardless, I
never saw a cat that wasn't glowing at 1400 degrees, as you are claiming yours does (n't.) I'd in fact be willing to put down a substantial wager that, besides you, the number of others that would report ever having seen a 1400* cat that wasn't glowing, would be exactly zero people. The only way I can see that kind of a reading happening is if your cat probe is faulty.
As to your other claim of never to have never seen your cat glowing brightly enough to where the cells become indistinct, or disappear...not sure what your deal is on that one. Wet wood? Seems to me that in BK threads over the years, I've seen some mighty bright cat pics posted, where it just looks like a very bright orange mass with no distinguishing features. I'm obviously not gonna go find them now; I'm an old man and my remaining time grows short. 😏
