New here. Excited to get going with pellets. (tired of cutting wood) I grew up with wood stoves and have installed many different stoves in different houses etc. My question now is I want to replace a dead propane stove in an area we haven't needed to utilized til now....with pellet stove and use the hole already cut into the outside wall with all new pellet approved pipe of course. The installation will be out the back of pellet stove with an adapter, then a T with clean out, then vertical up to the hole through the wall, then horizontal outside to proper clearance for an end cap. When installing wood stove pipe you can just cut the single wall pipe to fit the length you need. How do you do that with double wall pellet pipe? You can only buy it in certain lengths so how do I match up the exact length needed to fit through the pellet thimble that I will install in the existing hole?
thanks for any help
thanks for any help
