Help with stove pipe.
d-dayman
54
Central Pennsylvania
Currently getting ready to hook up my Jotul F55. I have a new insulated heavy wall liner installed in the exterior masonry chimney. Stove will be in the basement vented through the cinderblock wall thimble. I plan to use 6” single wall pipe as I am well outside of the 18 inch clearances. My questions are, do I run a 45 out of the stove and another 45 at the thimble, or should I just do one vertical run out of the stove to a 90 into the thimble? I would think the 2 45s would be be less resistance with better draft. There is already a 90 at the tee connector for the liner.
Also, what type of stove pipe are you guys using? I was thinking either HST all fuel or Ventis. I stopped in and saw some of the DuraVent stuff at Home Depot and was not particularly impressed with the quality.
Input is greatly appreciated.
Thanks
I think Home Depot sells DuraVent's DuraPlus chimney pipe. It's their triple wall value pipe. Their DuraTech product is much better. I'm not a fan of HST's design. I like the insulation end to be enclosed and not exposed.
I’m looking at the single wall stuff. Already have an insulated liner in the masonry chimney
Has anyone run their 45s out of the top of their woodstove like this? Should there be more vertical before the 45? I don’t really have a lot of room above the stove. Around 24 inches.
  • [Hearth.com] Help with stove pipe.
Some manuals say to have a vertical rise first before bending over, as that does help.
But if that leads to a 90 instead of two 45s, I'd surely go the way you have pictured there. I think that (allowing the gases to calm down in the longer angled tube before completing the turn with the 2nd 45) is likely to be a workable setup.
How tall is the chimney outside?
Finally, double wall stove pipe will actually help draft/prevent issues (if any). It keeps the gases warmer, also in the house.
The stove is designed to shed its heat. The pipe should not be seen as an additional heating device, in general.
I'd go for double wall. That's generally better quality (steel) too. Lasts longer.
Reactions: d-dayman
Chimney is 21’ from the thimble. I think double wall is definitely a better option. Just didn’t think it was necessary. May still go that route.
okay. At 21 ft I'd do the 45s as your pic indicates; I don't think draft will be a problem.
On the other hand, with 21 ft outside, your gases will cool down on the way up. If they reach < 212 F at the top, you might get creosote deposits there. Keeping them warm is important. For that avoiding the initial cooldown of a single wall pipe would be useful - i.e. that's an argument for double wall stove pipe.
oh. Wow. Even with an insulated stainless steel liner? I’ll go double wall then. What do I use to connect the Duravent double wall to the stainless steel thimble at the masonry wall. That’s also kind of why I was thinking single wall. Simpler connections.
I'm not sure what the best way is to connect to the thimble for your set up. I have seen folks using a 6" single wall piece to do that (if the double wall can't reach the (single wall?) thimble pipe).
I’ll have plenty of pipe there. It actually needs trimmed back some. I haven’t done that yet. Waiting to see how the setup will be with the stove and pipe.
Reactions: stoveliker
Yes, I set up a yurt stove like that.
Ventis is pretty nice from what I remember.
You can start with a 90, you’ll know if you’re having an issue pretty much immediately. The Tractor supply by me has a lot of single wall stove pipe, If you can’t find what you want at HD check them out.
I’d add a key damper too, a lot of basement installs have over draft issues because of chimney height.
FWIW I just did a two 45 basement install, when I was loooking that up I kept seeing a lot of references to at least 12” above the stove. I’m closer to 24” before the first 45, then a 12” section into the next 45 which is attached to the thimble. I have a key damper on mine, but my chimney is 25-30’. I’m still learning this setup but already discovering the key damper is helpful.
I also went with double wall pipe; I shopped around; turned out Menards was cheaper than pretty much everyone, despite me having to pay for shipping.
Ok. I’ve received the Duravent DVL double wall pipe to go from the stove to the stainless thimble. 2 45 elbows, 1 12” telescoping section, a flue thimble connector, and a stop pipe adapter with damper. After checking, I’m guessing I’m not able to use the stove adapter with damper. It is a crimped connection and the stove flue collar is made to fit regular 6” OD pipe. Sucks because I really wanted to use that piece with the damper. Is there a way to fit that in? Should I wrap the inside of the stove collar with rope gasket? It would be really difficult to get fire cement into that gap.
If I can’t use the stove pipe adapter with the damper, My thoughts are to come straight out of the stove with a 45 now. The un-crimped 6” stainless inner pipe fits perfectly into the stove flue collar.
Another problem is how do I fasten this attachment into place. The stove collar has predrilled holes to fasten the pipe in with screws, but that’s going to work good for single wall pipe, but not so much with double wall. How do you guys attach double wall pipe to the stove? Those predrilled holes will be covered by the outer wall pipe.
Thanks
A lot of times the double wall thimble slips over the stove connect, if not they sell a double to single wall adapter you can put right on top of the stove.
