Hello,
I recently purchased a home that has a 1997 Avanti PI pellet insert. The stove worked fine for about 3 weeks and then quit. The fan speed would not adjust. And the stove would go out. Called my local stove shop to come out and take a look. They performed a cleaning and They condemned the stove saying it would cost more to fix than replace stating the control panel was faulty. I was. Not satisfied with this. I found a new replacement control panel. Replaced and programmed the panel. Also replaced the upper and lowe snap disks. Checked the flow tube for clogs. Here is my issue. When the stove is cold and in the off position the exhaust and convection fans run at full. I can. Get the stove to run when in manual mode When all snap disks and flow switch are bypassed. But when stove is switched off fans still run even when cold. Any help or insite would be helpful. Thanks.
