Never thought I would look forward to temps back in the 20's in mid-April, especially this year. But hey, it was the perfect opportunity to fire up the new Progress Hybrid and put it through its paces.
I did have a small fire in it for a bit a couple of weeks ago, but last night was the first full overnight burn, and it's been running all day today as well. This stove is great - it puts my old CDW 246 - which I liked and used well for 26 years, not knowing what I've been missing - to shame. It definitely puts out a lot more heat, and it seems to burn the wood much more efficiently. The firebox is huge in comparison, the soapstone stays warm for hours after the fire dies down, the lowered floor of the firebox keeps the ashes in where they belong when you open the side door, and the huge window, that stays really clear almost all the time, makes the fire gorgeous to behold. The ash pan is about twice as big in volume as the CDW ash pan, so I am looking forward to emptying it much less often. I also like the design and positioning of the catalytic combustor chamber that should make it easy to service when necessary.
There were a few negatives - starting with a 750 lb. weight that took four of us to lift onto the hearth and get in position - though I did figure out a way to use my garage floor jack to move it around once it was up there. Of course in reality the weight is actually a positive, since it is the mass of the iron and soapstone that stores and radiates the heat so effectively.
The other negatives were a couple of small quality problems - a small chip in the right-hand top soapstone pieces, the center top soapstone piece didn't sit flat and wasn't centered properly on the the cast iron burner top, and there was a small but visible defect in one of the corner column castings. Woodstock sent me a new cast iron burner top and corner column, plus a new center and right-hand soapstone pieces for the top. Unfortunately the soapstone pieces they sent were not even a remote match in either color or grain to the rest of the stove, one of them was more badly chipped than the original chipped piece, and the new center piece still did not set flat, on either the original or the new cast iron burner plate, though it was better centered on the new one. So I wound up keeping the old soapstone pieces. I was able to make the center piece sit flat on the burner plate by shimming the brass shield (it rests on a bracket on the burner plate). I decided I could live with the small chip on the other soapstone top piece. All in all a little disappointing given the price of the stove, but I don't want to nitpick too much - it really is a beautiful stove, and even made in the good old U.S. of A.
I put a load of cherry in last night, not even completely filling the firebox, and there was a nice bed of hot coals in the stove this morning, with the stove still quite warm. You might notice in the second photo that I have positioned a fan on the floor behind the stove. I was originally a little disappointed that the Progress did not have a fan option like my old CDW did, but in truth the external fan is probably more effective and it's definitely much quieter. So all things considered I am quite happy with the stove and looking forward to a couple of decades of abundant warmth from this beautiful behemoth.
![[Hearth.com] New Progress Hybrid Up and Running [Hearth.com] New Progress Hybrid Up and Running](https://www.hearth.com/talk/data/attachments/131/131798-485e88c3e35b6de3c312bb5059653532.jpg?hash=NF1tNnKUsE)
