Wow. A few weeks back, I began looking for an insert for my upstairs fireplace. Not going to happen...it doesnt have the height.
After much grumbling about it, my wife suggested getting a new wood stove for the basement....one that we can actually use. I almost fell over tjat she actually said it ! Lol !
8 years ago, I put one in there. An Ardent Energy Aurora. Well my friends...if you want to smoke your neighbors out in a heart beat, put one of those thermostatic controlled little monsters in. Ive hardly used the thing.
Skip to today. I need a little advice. The house is 1700 sq ft. The basement is probably about 900 sq ft. I dont really care about heat output that much. Anything I put in there is going to help a lot. My main heat source is my gas furnace. My chimney is 6" and has 2 x 45 degree angles before it goes through the wall and makes another 90 degree up the stack. The stack is 27 ft if I remember correctly. Changing any of that isnt going to happen due to clearance issues. The chimney could be put in exactly the spot its in and the way its put in - full stop. Around the stove, I have 24" clearance behind and 4 ft to either side.
My main concerns are emissions and maintenance. I would like to go non-cat. I can easily make up identical copies of baffles and secondary air tube copies in my machine shop as they wear out.
Ive got about $2000 cdn for this project and Ill install it myself. The criteria are, the lowest emissions possible from a non-cat stove thats under $2k and sold in Canada. Thoughts ?
! That's going to be interesting getting it downstairs into the basement without getting killed. LOL. Obviously, pulling the bricks out and the door off will help, but with a 3.5cu ft firebox, it's still going to have a lot of iron to it.
