Hi all, first post and looking for some help.
My fiance and I are renovating an old farmhouse that's been in her family for the past 150 years or so (not 100% sure of when it was built, but we think between 1860 and 1870). It was heated with oil and hot water baseboards, but we removed that system in order to add additional insulation; we basically put up 2x8 framing behind all the exterior walls and will fill that with fiberglass. Also did new windows throughout, and also put in a high-efficiency propane system with central air as well. So we should be pretty well insulated and sealed up by the time we are finished.
One of the focal points of the project though is the fireplace in the living room. It's solid brick from floor to ceiling, 7' wide, with a 6' wide opening that's about 30" deep. What we want to do is put a free-standing wood stove in the opening. I already have an installer ready to drop in an insulated liner, fabricate a block-off plate at the top of the opening, and install a stove for us. The problem we are running in to is the 13" by 8" timber lintel. Everything inside the fireplace is non-combustible, and the exterior wall behind the fireplace is brick construction, so no combustibles to be found.
I'm looking for insight from anyone that has done something similar to this before (Ashful has a thread with a setup very similar to our's), and any suggestions on heat shielding for the wood beam/lintel.
Also, all of the clearances we reference for pretty much any stove are for distances to nearest combustible material. The only combustible material in our situation is the beam. What we want to do is push the stove as far into the opening as possible so the existing 15" hearth extension allows for adequate floor protection in front of the stove glass. How close to a non-combustible wall can we get the back of the stove? We are hoping to have it about 2" to 4" from the back wall of the fireplace, which is just plaster over brick.
I have attached several drawings I made of our fireplace with our preferred stove shown for reference (a Jotul F50 TL), as well as a few pictures. Please ignore the mess though, I'm in the process of repointing all the brick-work myself while our contractors work on the rest of the house.
Thanks for any input!
Scott
![[Hearth.com] New Stove in Old Walk-In Fireplace - Please help! [Hearth.com] New Stove in Old Walk-In Fireplace - Please help!](https://www.hearth.com/talk/data/attachments/162/162790-89320e5b8e03f8165a3c7a75b8dde7cd.jpg?hash=KDfTrOtfEb)
Scott
![[Hearth.com] New Stove in Old Walk-In Fireplace - Please help! [Hearth.com] New Stove in Old Walk-In Fireplace - Please help!](https://www.hearth.com/talk/data/attachments/162/162787-3046dda68bf46be6f60cdd34fdbe0a3a.jpg?hash=5uA3d60Ogu)
![[Hearth.com] New Stove in Old Walk-In Fireplace - Please help! [Hearth.com] New Stove in Old Walk-In Fireplace - Please help!](https://www.hearth.com/talk/data/attachments/162/162788-e525bc00c7d567103bb123cce8d86c4c.jpg?hash=Kx3f7CimJg)
![[Hearth.com] New Stove in Old Walk-In Fireplace - Please help! [Hearth.com] New Stove in Old Walk-In Fireplace - Please help!](https://www.hearth.com/talk/data/attachments/162/162789-495edda565df8bc2a299bb30bf3ce095.jpg?hash=7BQKn6dYEs)
